Question about Frigidaire Refrigerators
How to clean frigidaire counter ice maker epic452-ss
6ya staff
SOURCE:
0duro
  • 6 Answers
SOURCE: Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Posted on Feb 26, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: ice maker not making ice
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Oct 10, 2008
Anonymous
  • 700 Answers
SOURCE: Viking Ice Maker Leak
have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Posted on Jan 06, 2009
benham
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
Why is icemaker not working
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, model# FPHG2399PF. Please follow these steps to resolution:
    1)Make sure the ice maker power switch is on. This button is located on the ice maker itself.
    2)Make sure there is not a small cube caught in the ice maker itself. If there is, carefully remove it.
    3)Check your water filter. Water filters should be changed roughly every 6-8 months. Also make sure your water filter is seated correctly. Try taking out the filter and re-installing it. Listen for 2 clicks and make sure it is flush with the water filter housing.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FPHG2399PF Professional 23 Cu....
Currently the water is leaking from the ice maker. there is ice build up in the control box its self, and its leaking from there. No sure how the water is getting in tot he control box itself so i'm...
You are right - it is filling up with too much water. If you remove the front panel of ice maker you will find a screw there that adjusts the length of time that the solenoid stays open to admit water. Turn it counter clockwise to reduce the time and amount of water entering the ice maker.
If you need new maker get them cheap on ebay. eBayeBay
Sep 08, 2017 | Frigidaire FRS23H7CS Side by Side...
Ice keeps building up in bottom of freezer and on vent inside fridge and now fridge won't stay cold.
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 14, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
reyqyte
May 22, 2010 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Ice maker overfilling
OK i took a look at the ice maker. this has a shut off arm. i am guessing it always shut off automatically when you 1st had it right? but now it just makes too much ice. does it still do it if you lift the shut off arm up? if you lift it up and still makes to much ice then replace ice maker. (wait a couple of days)
if it stops making ice then just shut it off every other day thanks
Mar 28, 2010 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
Sep 05, 2017 | Refrigerators
I have a frigidaire model#frs23r4a side by side fridge the ice maker makes very little ice and is not working at all now, any repair suggestions ??
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...thumbs up
Aug 17, 2009 | Frigidaire FRS23R4A Side by Side...
Frigidaire side-by-side ice maker hose froze up
I've seen three solutions to this but havn't tried them yet. One was to gently turn the tube counter clock wise to separate it from the refrigerator and then clear the ice form the end of it another was to use a hair dryer to thaw it out and the third was to wrap warm washrags around it to thaw it out.
Jun 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
Jan 06, 2009 | Viking Refrigerators
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerators Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
