Question about Samsung Televison & Video
Samsung pn50b550t2fxza turned off and won't turn back on. Makes clicky noises. No obvious damage inside. Replaced power supply board. Same thing. What other issue could I be looking at?
6ya staff
SOURCE:
Cnythia Miller
  • 85 Answers
SOURCE: dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Posted on Apr 12, 2008
Keith Koene
  • 62 Answers
SOURCE: it wont turn on!!!!!
Found this one at Amazon.com
http://www.amazon.com/FSP-ATX-300GU-Supply-Replacement-Connector/dp/B001ANK8GC
Posted on Mar 23, 2009
tvservice306
tvservice306
  • 458 Answers
SOURCE: ln40a530 samsung lcd tv wont turn on
MAY BE PANEL LAMP BAD
Posted on Oct 21, 2009
toddthetvmd
Todd Thornton
  • 101 Answers
SOURCE: my samsung plasma tv went out and it just makes a
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
Posted on Jan 01, 2010
leepania
Pania Lee
  • 1099 Answers
SOURCE: i dropped my camera while the lens was out and now
That will be a mechanical problem and the camera is in a need of a repair.
Since you dropped the camera it is now Out of Warranty.
The repair of this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Jan 27, 2010
Samsung pn50b550t2fxza. clicks on then clicks off.
When you talking about a plasma TV oftentimes use the main board but plasma TV architecture can indicate that other problems can go wrong you need to count the blink code on the front of the TV and read and not Google that it will put you in a better Direction most likely it is the poppers and the Z sauce but it could also be the ask ex zuz. Again counter blinking lights on the front of the TV and report them here then I think we can help you better
Mar 07, 2018 | Samsung Televison & Video
I have a Samsung PN51E530A3FZXA 51" plasma TV. I heard a pop & saw smoke from left rear of TV. TV went black & had no picture or sound, however the red power light stayed on.
Unfortunately plasma tvs are a lot more complex to service, instead of 2 or 3 boards there are a half dozen at least. I would guess when the main PS board went out it took some other boards with it. I don't have a manual for your set but I would look at the power supply sub boards, there generally are 2 of them, or on some models that is parts of the other boards. Generally there is a legend to see what voltages are supposed to be present at what places, samsung is good about making the test points on the boards. Also there are fuses on most the other boards and its possible one of those has blow, it won't be a typical fuse like your used to seeing, some are a small green component and some are white mini fuses...Good luck!
Nov 10, 2017 | Samsung Televison & Video
My samsung flat screen makes loud noise and wont turn on
sounds like a power supply board problem. Be careful. I would up plug it from the wall socket.. the sound u hear MIGHT be something on the circuit board heating up and about to POP. The power supply boards are not hard to replace. just make sure it is unplugged and be careful they can carry a charge even unplugged. Caps etc can Zap u.. as I tell every one , take picture of the insides of TV and the power supply board and a close up of all the numbers that is on the power supply. order the exact same part.. do not remove the bad board till u have the new one ready to go in.. good idea is use a grounding strap. the only cost a couple dollars or so.
Jan 07, 2015 | Samsung Televison & Video
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
My samsung HP-T4254 keeps turning off in the middle of watching something and makes a clicking noise similar to the one it makes when you go to turn the tv on or off. This noise does not stop until I...
Ur tv power supply board have dead componnents parts call capacitors.Take ur tv aparts,the board that the a/c power cord go into it.That ur power supply board.Searches all around the power supply board and it supporting boards for these dead capacitors,they bulges up on it top,or puff up on it top.These capacitors parts that bulges up on it or puff up on it top must be replaced.U know basic electronic and how to solders?Replaced these dead bulges or puff up capacitors well get ur power back to normal and work.Or tries websites like Shopjimmy.com,Ebay,com to buy a refurbish power supply board for the replacement.
May 17, 2010 | Samsung HP-T4254 42 in. Plasma Television
When the tv turns on it makes a buzzing noise then it turns off, its a Samsung LE46M86BD
noise on R or L side need replaced inverter board
if no ..need replaced power supply board....
Dec 05, 2009 | Televison & Video
My 50"nplasma makes clicking noises
There is a problem with the power supply. The clicking is the power regulator continuously turning on and off. This was most likely caused by a power surge.
The first thing to check is a visual inspection of the power supply and look for bad capacitors. This can be done by looking for ones that look bubbled where the top metal part with the T is ballooning out. If you see any, replace these with the correct voltage and fared rating (both located on the capacitor itself) by soldering them onto the power supply.
This will fix the problem most of the time but the power surge could had also damaged other components in the power supply so if you are not comfortable with soldering or did not see any bubbled capicators, or replacing the capicators did not fix the problem replace the power supply board.
Oct 05, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Ekse
