Question about Juki DDL-8300
How to fix timing on a juki ddl-555 sewing machine
    New Friend:
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Posted on Apr 23, 2010
    Scholar:
  • Juki Expert
  • 178 Answers
HI U WILL START UR ADJUSTMENT BY HIGHT OF NEEDLE BAR FIREST U WILL FOUND TOW SLASH ON NEEDL BAR THE HIGHST ONE FOR HIGH OF NEEDLE BAR BRING THE HANDWHEEL AT LOSET POINT DOWN AND LOSE THE SCREW FROM INSID AND MAKE THE NEEDLE BAR AT HIGH SLASH AND THE SECOND SLASH FROM DOWN FOR TIMMING NEEDLE BAR WITH HOOK AT THIS POINT TURN THE HANDWHEEL AT THE SAME DIRECTION UNTIL PLAD POINT FOR HOOK COMES TO SURFACE OF NEEDLE
Posted on Oct 31, 2009
    New Friend:
Juki DDL 555-4 due to broken needle the bobbin shuttle is now stuck. It wont move at all, any suggestions?
Posted on May 12, 2011
  • Shirley Neibarger Aug 25, 2017
    I usually try to take off the throat plate, and the feed dogs, put nine or ten drops of oil on the shuttle and try to jiggle my handwheel until it lets go. Sometimes it isn't the needle piece that is stuck in the race but maybe the needle caused the moving knife blade or the stationary blade or the lasso, that holds the thread when it is cut, to break and wedge a piece into your shuttle. Once your needle plate and feed dogs are off, you can see what is happening and repair it.
    New Friend:
My modle date is 867
Posted on May 16, 2013
    New Friend:
MY MACHINE TURNS ON AND WHEN PUSHING PEDAL IT SEEMS TO WANNA GO BUT NEEDLE DOESNT GO UP OR DOWN AND KNOB SEEMS TO BE LOCKED.
CAN SOMEONE HELP?
Posted on Apr 09, 2013
  • 1 more comment
  • Moe Gingerich
    Moe Gingerich Nov 25, 2014
    Try to getnly move teh hand wheel forward and backward a little at a time. You should be able to losen it taht way.
  • Moe Gingerich
    You may have thread stcuk ibehind the bobbin case area. You need to carefully pull out all the strands and make sure ti is all clean. Then you should be in business again. This is a common problem.
  • Shirley Neibarger Apr 03, 2016
    Take your needle plate off and see if there is a broken cutting blade, broken needle, or some other small metal piece that you can get out with tweezers and put a drop of oil in the race where the bobbin case fastens in. Turn the motor off and see if you can turn the hand wheel towards you.
4 Suggested Answers
6ya staff
SOURCE:
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
Anonymous
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
hi , i am looking for needles for the juki ddl 555 industrial machine , any ideas
thanks
Posted on Jan 20, 2010
johnytziotis
SOURCE: Where can I find a free manual for my juki sewing
HI EVERY BODY I AM FROM GREECE AND LOOKING FOR MANUALS FOR A JUKI 1120 OF 1120 IF SOME BODY CAN HELP ME PLEASE WRITE ME ON johny.tziotis@gmail.com thanks
Posted on Nov 09, 2010
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
Juki ddl 555 lock
Does this look like your machine?
JUKI DDL 5550N Manuals
Jul 07, 2014 | Juki Sewing Machines
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
What type of oil is need fro juki ddl-555
hi there
you can use juki deffrix oil no.1 or in your local market light and clear oil for industerial sewing machine
May 22, 2010 | Juki DDL-8300
What needle type is used for the juki ddl 555?
Regular sewing machine needles. Choose the needle type and size according to the type fabric or thread being used.
http://www.euronotions.com/pdf/Schmetz_Sales_Guide.pdf
Mar 18, 2010 | Juki DDL-8300
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Juki DDL-8300 Logo
3,460 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
