Question about Polaris Pool & Spa
Could the setting on the polaris 280 thrust adjuster increase/decrease the cleaner getting stuck on my rounded pool steps?
    Top Expert:
  • Polaris Master
  • 30,377 Answers
  • Betsy Kraushaar
    Betsy Kraushaar Sep 19, 2019
    Thanks Andrew!!!!
  • Andrew Taylor
    Andrew Taylor Sep 20, 2019
    You are very welcome :>)
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Posted on May 10, 2009
Dale Cobb
  • 366 Answers
SOURCE: Polaris 340 pool cleaner, will not reverse
A big problem with this cleaner is that the screws come loose with vibration. You'll have to disassemble the cleaner to get to the power module, once you have to power module out, remove the endcap and check the screws on the cams that engage the reverse drive mechanisms. The main problem is when the screws come loose, they won't fully engage the reverse drives and will sometimes cause the cleaner to stop while it should be reversing, then continue on forward mode. I guess the best advice I have is to make sure all the screws are tight, but not over-tight as you can pull the threaded inserts out of the plastic. 1dcd685.gif
Posted on Sep 19, 2009
Anonymous
SOURCE: My Polaris 280 pool cleaner trips the circuit
This could be caused by an overloaded circuit. Make sure that you don't have too much stuff plugged into the outlet and try again.
Posted on Jun 21, 2010
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: how do i change the axle of a polaris 280 pool
Here is copy of the users manual for these pool cleaners. It has a detailed diagram of all of the parts that is pretty easy to follow. Find the section that you need to change and you should be able to see how to access it. Hope that helps.
http://www.backyardcitypools.com/images/Polaris/Polaris-280-manual.pdf
Posted on Mar 30, 2011
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: I hooked up a new Polaris 280 pool cleaner to
I would first take it out of the water and check for proper wheel RPM. If it is less than 28 RPM or you are getting no movement at all, it is going to be a problem with the power source. It is likely going to be that your booster pump is missing, malfunctioning, or is not installed properly on the pool cleaner. There are a few other things to check. Clean the skimmer, filter and pump basket, clearing any debris that restricts water flow. Check the hoses, connections and swivels for leaks. Try removing the blue restrictor disk from the UWF or if an adjustable gate valve is installed on the booster pump or cleaner line, open it completely so water can flow freely.
Posted on Jul 21, 2011
My wheels are not turning on polaris 280
Make sure that your thrust jets are properly positioned. You will also want to check for any obstructions in the wheels or axles that would restrict movement. Often with these automatic pool cleaners, one of these two problems is causing restricted movement in the wheels.
Jul 02, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Where the filter screen / hose connection attaches to the wall of the pool there is a lot of water pressure coming out of the black cap.I have replaced with new ( very expensive ) but same problem is...
Make sure that the blue restrictor disk in in place to decrease water flow. That is a common problem with these pool cleaners. If that still isn't enough, you cleaner should have also come with a red restrictor disk that limits water flow even more. You could also try unscrewing the pressure valve to decrease RPMs and pressure.
Jun 09, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Pool sweep wheels are not turning
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
How do i change the axle of a polaris 280 pool cleaner. I am trying to change the axle on my polaris 280 pool cleaner. I can't seem to get the top off so that I can reach the screws to change it out. ...
Oct 10, 2009 | Polaris 280 Black Pool Cleaner
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
Pool & Spa Logo
59 people viewed this question
Top Polaris Pool & Spa Experts
David Spradling
David Spradling
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
