Your TV has no independent IP address. The IP address correponds to YOUR internet connection and you can get it making a Google query for "My IP"
Actually, to save you the work for searching, you can use this link
By default, the IP address will automatically be assigned by the router. If you want to set a fixed IP address, there is a menu option to do so under SETUP on the television. You may enter any fixed IP address within the accepted range of your router. (It is recommended to set the television to DHCP mode so it will automatically be assigned an IP address by your router.)
You need to use Proxy server to get United States ip address in Canada.But you cannot get US ip address legally from any service providers in Canada .To check ip address before and after using proxy visit
the site Ip-Details.com .
You need to setup a fixed IP address for this printer that no other users will use this address. Please follow the printer user manual in how to setup a fixed ip address. You will need to diable the DHCP ip address in your printer.
Secondly you will need to reserve this IP address in your router's DHCP server which corresponds to your printer's MAC address (a unique machine address code for each device). Please follow this properly in your router's user manual.
Thirdly please unblock the firewall settings in every PC that needs to use this printer. Usually this will be unblocked when you install the printer driver or program that comes with the printer.
Fourthly, please install this printer program properly that comes with this printer. You should detect this printer's fixed ip address during the process of the installation.
Please let us know any problem you may have in future.
I need to know a little bit of information. Could you please go to start>run>cmd. In the command prompt type "ipconfig /all" without the quotation marks. Please let me know the information displayed.
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address 192.168.1.2, try 192.168.1.200. If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card.
If that doesn't work please contact Linksys Technical Support.
