Question about Exercise & Fitness
ERROR 4 ON XTERRA TREADMILL - Exercise & Fitness
How do I resolve Error 5 on my XTERRA Treadmill
Quoting from XTERRA on website
The E5 Error is specific to the TR2000e and the TR3000e treadmills.
The error code triggers when an object is detected by the folding sensors on the underside of the treadmill. The folding sensors look like small trapezoids: two on the back and two on the front. Make sure there are no foreign objects underneath the treadmill. If no objects are present, inspect the sensors for damage. If the problem persists, please contact customer service.
Customer service department 877.654.3837 x4 or fill out a customer service request form.
https://www.lifespanfitness.com/fitness/resources/articles/what-does-your-treadmills-error-code-mean
Jun 19, 2018 | Exercise & Fitness
Do not have ownes manual. how to correct error LUbE on Xterra TR150 treadmill
Hello, Mary -
I went to the Xterra Fitness homepage:
http://www.xterrafitness.com/
Then, I clicked on the Support link in the upper right corner of the homepage.
That brought me to this page:
http://www.xterrafitness.com/support?ref=top-nav
Where I saw the link for "I Need A Service Document".
I chose that link.
That choice brings you here:
http://www.xterrafitness.com/support/supportdocs/
I do not see your model treadmill listed on that page. I suspect LUbe means your treadmill needs lubricating. The General Maintenace instrucitions (link the last one in the first column on the Support Documents page) will give you some information.
This is the link to the Contact Us page for Xterra Fitness:
http://www.xterrafitness.com/contacts/?ref=footer-link
You may want to send an email to find out how you can obtain an owner's manual for your model of treadmill.
Best wishes.
Mar 02, 2018 | Exercise & Fitness
T5 treadmill error 4
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.gympart.com/TSB/Matrix%2520Fitness/Treadmills/T5_G1_TM65/D/T5x_G1%2520Error%2520codes.pdf&ved=0ahUKEwjBvZbqzJLTAhWdF8AKHTIOCf0QFgghMAA&usg=AFQjCNG-fvYDtHHAA9AhxI3uFbtQXKB8mA
Apr 07, 2017 | Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Error 4 on my avanti 380
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. Check for treadmill error codes
Mar 13, 2016 | Avanti Fitness AT380 Treadmill
Error 6 message on xterra 3.0 treadmill
I have the same problem... It doesnt work.
Apr 10, 2014 | Xterra Fitness Xterra Treadmill
Treadmill error code 4
You will need to give more detail, like make and model numbers? without that information there is really little help anyone can give except contacting the manufacturers website for the manual to download.
Mar 01, 2014 | Exercise & Fitness
Xterra tr3.0
New xterra trendmill will not start says error 5 help
Feb 03, 2014 | Xterra Fitness Xterra Treadmill
Error 4 on Exerpeutic walk to fit treadmill
please see the error code 4 and proceed for fix it.
Happy New year. God bless you
Run the software calibration for fix it.test the speed sensor. The belt is running over the normal speed.
vwaaaabjru5erkjggg==
Jan 01, 2013 | Exercise & Fitness
Exercise & Fitness Logo
51 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
