SOURCE: pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1: Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
SOURCE: TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
open and, replace the rechargeable batteries
SOURCE: my mad catz headset wont turn on but it will
THE SAME THING HAPPEND TO ME I SAY SEND BACK OR CHECK THE INSIDE
