SOURCE: Konica Minolta Bizhub 250
I've had this a couple of times. Bit of a pain the black & white 250's for this fault.
Basically when you change the drum (and dev) you need to go into service mode anf run an F7 asap.
If the machine doesn't allow you to run an F7, you need to go into counters and reset the drum/dev one.
Bit of a pig cos all you're hearing is 'bee-bo-bee-bo'!
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
SOURCE: bizhub C 250 stops printing! Hepl please!
Sounds like the controller has crashed.
If you have a Fiery, reboot it and see what happens.
If that does not help you better call a Technician as it may need to be reloaded.
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Touch utility button then on the touchscreen hit in the following order User Settings, printer settings, print reports, configuration page, and the start button
