Question about Frigidaire Refrigerators
New fridge not getting cold
Fridgidaire freezer on top model. 20.5 cu ft
    New Friend:
  • 46 Answers
If new and under warranty contact supplier. If you attempt to fix while under warranty and cause further faults then you may void warranty.
Posted on Oct 03, 2019
6ya staff
SOURCE:
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
Anonymous
  • 12 Answers
SOURCE: amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Posted on Aug 05, 2008
Anonymous
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
Anonymous
  • 68 Answers
SOURCE: my kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Posted on May 02, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Is there a way to disable the alarm on my freezer?
unplug the power line to the alarm. The freezer will still work and tape off the wire.
Posted on Jan 14, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Freezer gets cold but refrigerator does not
blocked air flow from freezer to fridge. Could be ice build up. May have a faulty auto defroster. Freexer is only part that gets cold. The fridge gets it cooling from the freezer.
Aug 02, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
Fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
https://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
https://www.fixya.com/support/r3885294-refrigerator_troubleshooting
https://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Kenmore refrigerator 25364150400 fridge won't get
check your evaporator coil in freezer it is froze up ,need to check to make sure defrost timer is working. Also check drain line.
Apr 10, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
