Slide the frig out, (Unplug Frig. first) remove the cover so you can see the condenser, beside the condenser there is a switch that has to be carefully removed w/(fasteners) Take to your nearest appliance store, last time I did this it was like $52.00. Carefully plug-in, take not were the wiring goes usually they only fit just one way. reassemble cover, plug-in you should hear it kick on, good luck.
SOURCE: zanussi zk73/46ef freezer working fridge is warm
if this is an air blown cabinet defrost it for 48hrs leave the doors open then try it. hope this helps
SOURCE: Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
SOURCE: Maytag Performance Side by Side Fridge Freezer is not cooling...
sounds like a bad compressor.
SOURCE: New Fridge beeping but no cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
