Question about Toshiba Office Equipment & Supplies
Toshiba studio 2506 firmware update after error code c260 how to solve
6ya staff
SOURCE:
didi2005
  • 727 Answers
SOURCE: F103 ERROR CODE IN TOSHIBA E-STUDIO 282
F103 indicates HDD transfer time-out.
U can try format the HDD (08-690).
Then u perform the bad sector check (08-694). *take long time
If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
* replacement of HDD require firmware update
Posted on Jul 02, 2009
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: firmware for e-studio 282
I need firmware becuas the machine in errer f 103 i chage the HDD
than HDD need the softwer Pleas Give me a free softwe side
Posted on Jul 06, 2009
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: What is error code C260? Fixable?
OK first of all the C260 code indicates a scanner lamp issue which is not major. But...Be VERY careful here as I need to know what you mean by "damaged"
I ask this because this being a full color copier you can run into so much money so fast it will make your head spin. They are complicated machines and you can run into a lot of issues.
Was the machine dropped? What were the circumstances that caused the machine to become damaged.
Since you are purchasing it damaged I would not even think of paying more than $200 to $300 as that is about what it is worth at the maximum.
I've got one in perfect condition with only 16,000 color copies on it that I can not even get $1,000 out of locally.
Posted on May 12, 2010
muntejaya
Muntejaya Ginting
  • 10421 Answers
SOURCE: I need a software of Toshiba estudio352 Firmware
Just download the driver here:
www.driverfiles.net/.../Toshiba/.../download/page,sh,19807,221,12,.html
Posted on Jan 13, 2011
patrick hopkins
  • 132 Answers
SOURCE: My toshiba e-studio 282 displayed error C260 How
first off try firmware if that does not work it could be the exposure lamp faulty or the slg board (board under the metal plate in the optics cavity) faulty ro the inverter is faulty. but also make sure that the white strip under the glass is clean
Posted on Mar 08, 2011
I need to reset the f101 code on a toshiba 477s studio as I enter service mode
F101 is HDD related error...
If HDD no issue, format HDD update firmware will solve
Feb 24, 2017 | Toshiba Office Equipment & Supplies
My Toshiba e-Studio 2506 shows the error "Call for Service C413", what can I do to solve this problem? Help me please!
perform the following:
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "3" or "4" to "0",
then press [OK] (to cancel [C413 / C414]).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
Sep 27, 2016 | Toshiba Office Equipment & Supplies
I have a Toshiba e-studio 600. When I turn it on.suddenly it showed error code c260. And then I power it off. But when I power it on again. It starts work.it always do like this again and again. In...
The wrench sign indicates it needs maintenance. Look up your service contract, to check who you should call for this.
When you don't have a contact you could call a Toshiba certified service centre close to you.
Feb 04, 2015 | Toshiba Office Equipment & Supplies
How to fix c260
C260 Scanning system
related service call
Peak detection error: Lighting of the exposure lamp
(white reference) is not detected when power is turned
ON. Replace the exposure lamp ..
Jul 03, 2014 | Toshiba e-Studio 232 Black and White...
Download printer driver
toshiba estuido 600 giving error c260
Jul 03, 2013 | Toshiba E-STUDIO 650 Copier
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
My toshiba e-studio 282 displayed error C260 How can reset it? Pls help me
Mar 08, 2011 | Toshiba e-STUDIO 282 Black and White...
Service Required Error code F100. What do we need to do?
F100 indicatest HDD failure...
The best way to solve it is to replace a new HDD & update firmware~~~
Oct 07, 2010 | Toshiba e-Studio 350 Copier
Toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
Jul 22, 2009 | Toshiba E-STUDIO 650 Copier
Jul 02, 2009 | Toshiba e-STUDIO 282 Black and White...
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
