Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin, then twisting the cap at the bottom front of the machine to empty the drum of water!
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Posted on Sep 16, 2009
6ya staff
SOURCE:
I have a Hoover VHD Sensor Dry 1400 AAA that trips the house fuse each time I turn it on. What should I do?
disconnect from the power outlet and call an technician to find the short or earth leakage problem
Feb 20, 2018 | Hoover Washing Machines
How to reset the delay start on a hoover 1400 AAA vision hd
consult the manufactures website for a manual free download eric
Dec 25, 2017 | Hoover Washing Machines
My hoover optima 7 kg 1400 aaa will not go into the spin mode ?
drain pump needs to be replaced, washer needs to be empty then will spin. please comment.
Dec 03, 2014 | Hoover Washing Machines
Hoover vision hd 1400 aaa manual
I have hoover vision hd 1400 aaa
In proble stain blaster
I oll redy clean thing and check water vest pipe
Nothing to blocking
Jun 16, 2013 | Hoover AAA140 Front Load Washer
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
Jul 03, 2012 | Hoover Washing Machines
My Hoover VHD 1400 aaa has the front concrete weight off
This weight helps to balance the machine. needs to be put back on or replaced. Machine will not operate properly without it.
Mar 28, 2011 | Hoover Washing Machines
Hoover Quattro Whisper 1400 washing machine AE 240 I would like to clean the filter as scum builds inside the rubber seal on the door Cant find the filter, no obvious opening
On the front bottom of the machine there is a plastic 'kick plate' that clips/pushes on. Remove this plate and you will see the filter with a cover secured by a star/phillips screw. Loosen screw and twist this cover off to gain acess. Don't do what i've just done and twist without removing this screw as it breaks it:-(
anyone who knows where i can get a filter cover please post back!
Aug 12, 2010 | Hoover Washing Machines
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Washine machine fills but drum does not turn
hoover hd 1400 aaa motor turns and so does drive belt but the drum doesn't? what is the problem?
Sep 25, 2009 | Hoover Washing Machines
Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Apr 11, 2008 | Washing Machines
Washing Machines Logo
376 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
