Question about Braun Irons
I have a Carestyle 5 Braun Iron which leaks water everytime I press the steam button?
  • 5,919 Answers
A steam iron generally produces steam in use as the movement allows water in the reservoir to move around and small amounts will escape into the heated sole plate.
The button to produce extra steam is mostly a small pump similar to those found in trigger sprays and hand soap bottle pumps and this is connected to the sole plate by a small-bore hose. It is far from unknown for one or more of the little hose(s) to become disconnected, often because of a limescale build up - even though the modern steam iron is advertised as needing only tap water, this is suitable only in soft water areas. Irons used in hard water areas tend to have a much shorter life so an alternative is advised.
My description doesn't apply to every steam iron - in some older designs the extra steam button opened a valve in the bottom of the reservoir to allow water to gravity feed into the sole plate. Although almost exclusively found on irons from the premium end of the market they were a nightmare of rods and rubber seals no longer lasting or reliable than those with a cheap plastic pump.
Clearly your iron needs dismantling and repairing if you can do this yourself, or replacing if you can't due to the disproportionately high repair shop cost. Some years ago my wife gave up on premium irons and began to buy the cheapest and was at first happy to replace them fairly often saying she found them no better or worse than the expensive ones. The first couple only lasted a couple of years each but the last one is now six or seven years old and still going strong.
Posted on Sep 22, 2019
    Top Expert:
  • Braun Master
  • 54,386 Answers
Your Braun iron has failed
6ya staff
SOURCE:
Anonymous
  • 43 Answers
SOURCE: swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Posted on Sep 18, 2009
Anonymous
SOURCE: shark iron-61468-10 steam button stuck on dowm
Pull the button up. You may have to coax it up; I pried it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only). Below the button is a stem that operates the valve, gently full it back up with a pair of needle nose pliers (careful - the stem is plastic). Replace the button (align the stem into the hole on the bottom of the button. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :) It seems like it sticks when the iron is left unused for a period of time; as if the valve sticks when dry. I'm going to leave water in it this time, although the instruction manual says not to.
Posted on Feb 07, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Rowenta model 1700W. Water leaks out front of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
https://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
jacque peters
SOURCE: steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
Posted on May 08, 2012
E Avila
SOURCE: Rowenta DA75 - Won't Steam
Using tips from previous commenter, Jason Collins, I thought to check for any blockage in the water flow.
Anyway, if you take out the water "tank" there is a black piece and a white/clear piece that are removable, I removed the white/clear piece and now it works fine! Hope it works for ya'll too.
Posted on Oct 26, 2012
Hi I have a Braun carestyle iron. The steam element does not work when ironing but steam comes out when the iron is on the pad
Get your netgear tech issue fixed instantly by calling
<a href="http://rokutechnicalsupportnumber.com/netgear-support/">netgear tech support</a>
Nov 18, 2017 | Braun Irons
I just bought this iron in March 2015. The iron leaks water all of my clothes when I press the steam button. I have it set on the highest setting for iron and steam.
Increasing the temperature setting can ease this issue, however it is important to consider the type of fabric you are ironing.
1st option: Fill the iron up, and let the iron stand as the iron heats for little while before using. This may allow more of the water to be converted to steam.
2nd option: You could try using deionised/distilled water in your iron.
If you find that the water leaks out sporadically, it may be worth pushing the steam button once or twice before applying it to clothing.
I have attached a link with a little bit more information How to Stop Steam Iron From Dripping
Apr 30, 2015 | Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 14, 2012 | Irons
My argos steam generator iron is leaking and now does not produce steam, whats the problem and how can i resolve this problem?
tank or ports clogged: Disassembly and inspect , replace tank and seal if badly clogged or leaking. Emptying iron after each use allow heat to evaporate emaining water and help preventing clooging. Inspect valve and linkage: clean and replace as necessary.
God bless you
Jul 22, 2012 | Irons
Steam not working on iron then lots of water pouring out of holes
May 08, 2012 | Tefal Pro Express GV 8120 Iron
Water keeps coming out after pressing steam button
hi i have just looked this information up and apparently that using 100% distilled water can cause your iron to spit and leak, to solve this problem you should press the steam button and keep pressing it until there is no water left in the iron, then try it again, if it still does this, repeat a few times and then the iron should be fine
hope this helps
Feb 28, 2011 | Rowenta DG5030 Iron
I have bought a swan s15040n steam generator iron and it does turn on but I can't get to generate any steam. I have tried holding the steam button down for 20 seconds ( and more) but still nothing. Any...
Try holding the iron well below the base with the cord straight and pressing the steam button, this will release any airlock caused by a changing the filter
Jul 13, 2009 | Black & Decker Steam Generator SG200 Iron
My Braun Si 3120 Optistyle Iron is leaking water from steam holes
Scale buildup is unseating the rubber seal. Disassemble the iron. (Water filler hole part pulls directly forwards and can be pushed out from behind with a screwdriver.) Otherwise it's fairly straightforward. Clean scale off baseplate. Seal with silcone gasket before reassembly.
Jan 10, 2009 | Irons
Steam generator iron beebs when button pressed but no steam green flashing light on aswel
heatman101
Sep 21, 2008 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
56 people viewed this question
Top Braun Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Braun Iron Expert? Answer questions, earn points and help others
