Question about Fisher and Paykel Washing Machines
Fisher and paykel washing machine fault code 248
    Habit-Forming:
  • Fisher and P... Expert
  • 199 Answers
How can someone say it is definitely a control board faulty when they don't even know what sort of machine it is? Fault code 248 is used on the F&P aquasmart top load machines. It is a fault displayed when the water level drops during wash & it has to keep topping up the water level. Before doing any of the following, check that the drain hose is not pushed too far down into the drain pipe. It has to be able to release any suction after draining so it doesn't syphon water out next time it fills.
Here is info on 248 fault code.
248. (11111000) SmartPump Top Up Fault
More than 6 attempts have been made to top-up the water level in the bowl during recirc. This then signifies that the flapper valve has not closed full and some water is diverting to the drain.
Primary Source: Poor Flapper Seal.
Action: 1) Clean any foreign objects out of the pump, concentrating especially on the flapper and drain/recirc port areas.
2) Remove the flapper to ensure no foreign objects exists below and
around the flapper.
3) Check for flapper damage, especially the lip seals. If damaged,
replace.
Secondary Source: Cap not tight, warped, damaged (worn).
Action: 1) Check that the hood/cap on the drain pump are tight. If loose and screws are difficult to tighten, foreign objects could be in screw boss. Remove pump fully and inspect/replace if in doubt.
2) Check the cap is not warped or it is not excessively worn in the
area where it contacts the flapper. Replace the cap if warped or
worn.
Tertiary Source: Damaged Pump Housing Port
Action: Check there is no excessive wear to the pump housing port caused by foreign objects. Replace pump if necessary.
Quaternary Source: Motor Control Module.
Action: Replace Motor Control Module.
Posted on Sep 28, 2019
    Master:
  • Fisher and P... Master
  • 738 Answers
If its a top loader then a faulty motor controller.(computer main board )
6ya staff
SOURCE:
Anonymous
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
Anonymous
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
Anonymous
  • 41 Answers
SOURCE: My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Posted on Jan 31, 2010
Anonymous
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
luisa_sgro
  • 713 Answers
SOURCE: Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Posted on Jun 27, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
I have a fault code 249 from my Fisher and Paykel 8kg washing machine. What does this mean?
I didn't know the codes went this high! it will be a motor controller fault I would suggest, as all other faults above 140 are motor controller.
Aug 28, 2013 | Fisher and Paykel (IWL12)
Jan 24, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel washing machine fault codes
Mar 12, 2008 | Washing Machines
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Open Questions:
Washing Machines Logo
63 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
