Question about Fisher and Paykel Washing Machines
Fisher and Paykel Intuitive Eco Washing Machine IW811 fault code 9. What is it? how do I fix? how do i reset?
    Habit-Forming:
  • Fisher and P... Expert
  • 199 Answers
When a new control board is fitted, it needs to be programmed to tell it what size the machine is. If it hasn't been programmed it will come up with error code 9. If it is a board that has been in for some time and has been ok, try setting the size again. I have seen several times, machines loose the setting for some unknown reason. Once reset then it worked ok again. If it won't accept a size setting, then you have to replace the main board.
Posted on Sep 28, 2019
    Master:
  • Fisher and P... Master
  • 745 Answers
That is a sizing problem ,if neither board has been replaced recently,then faulty board
4 Suggested Answers
6ya staff
SOURCE:
luisa_sgro
  • 713 Answers
SOURCE: Hello -Just looking for help on fixing a service
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Posted on Jun 04, 2010
tng15606
tng15606
SOURCE: fisher and paykel intuitive eco washing machine
intuitive ECO Model IW811 display error code 49...any one can help me
Posted on Apr 28, 2012
Jeremy Davenport
  • 64 Answers
SOURCE: Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Posted on Aug 06, 2012
Intuitive Eco - code 49. What does that mean?
faulty cold water valve, if that doesnt fix it then fault computer board
Feb 27, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive Iw509nw fault code 9 what's it mean
the size of the machine needs to be set. if you recently replaced a board the first thing you need to do is 'size set' the machine and instructions should come with the board. holding wash temp up/down and pressing power should get you into the menu, though it's too much to explain here.
Aug 16, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Aug 06, 2012 | Fisher and Paykel Washing Machines
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Open Questions:
Washing Machines Logo
56 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
