Question about Samsung Washing Machines
My samsung wa75b9 washing machine is not allowing me to select a program once switched on. All lights come on for program, water level etc. but does not show an error n the display.
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
Tony Coultrip
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
Anonymous
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Posted on Apr 17, 2008
Anonymous
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
david_davemo
  • 880 Answers
SOURCE: I have an 03 error displayed on a Bosch WFK 2801
03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Posted on Dec 01, 2009
Dc68-01776B samsung washing machine not working
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 25, 2013 | Samsung WF218AN Front Load Washer
Samsung washer won't fill with water
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 04, 2012 | Select Brands Washing Machines
WASHING MACHINE NOT RETAINING WATER
Make sure that
A. the drain hose is above the hight of the water level.
B. there is an "air gap" between the drain hose and the stand pipe as the water can "syphon"out.
May 04, 2012 | Samsung Washing Machines
I have a samsung washer machine and it fill up then stops and an error code de comes up and an alarm sounds and it stroped working
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Aug 08, 2011 | Samsung Washing Machines
HI My LED light does not turn off after a wash cycle ends. And I am unable to power on the machine again and run. The panel is blank and nothing lights up or is able to be set. I've checked...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 14, 2011 | LG WM0642H Front Load
Washing machine water continue to come into the bowl and the cycle for spin etc seems a problem of sensor,i d'ont know with the LG fuzzy logic washing machine.May be to reset it,HOW?
Jul 05, 2011 | Washing Machines
Wf310 wont start lights are on but when wash lights up nothing happensWf310 wont start lights are on but when wash lights up nothing happens
start with the door switch as if this is faulty the program controller will not work.If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jul 02, 2011 | Hotpoint Washing Machines
My Samsung WA75B9 Washing machine give an error of 1E if we try to start it how can we dignose this problem?
Disconnect the power for some time and if the machine shows the same errror it indicates a faulty application on the board.
Please make sure that the top lid switch is closing, check the lid switch mounted at the hinges to activate the main controller. check the wires to the switch.
secondly try to disconnect the output lines to the main motor and the inlet valve. if the fault changes then one of these has failed and needs a change.
Otherwise the main program controller is a suspect.
Mar 25, 2011 | Samsung SW62ASP Top Load Washer
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
https://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
https://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
