SOURCE: sony xplode 1000 watt amp
just make sure that your wiring is for 1000w or more
and check the + and - even at the speakers.
SOURCE: My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
SOURCE: sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
SOURCE: sony xplode 1000w amp has green light puts out no power to subs
check the speaker, the subs. i had same problem, same reading on volt, its correct as way it should be. if its not the rca plug then it has to be speaker, i replaced the amp and it wasnt that, it was the speakers after all...
