Refrigerators Logo
Richard Pyburn Posted on Sep 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire FFHT1826L 18.2 cu. ft will only dispense crushed ice. I suspect the solenoid that activates the cubes is no longer working
Ronald Rissel
Level 3:
Master:
  • Frigidaire Master 715 Answers
  • Posted on Oct 05, 2019
Ronald Rissel
Frigidaire Master
Level 3:
Master:
Answers
715
Questions
Helped
258780
Points
1075
You are right! That is the most likely cause of the problem you described.
4 Related Answers
Carmen Mikulic
  • 415 Answers
  • Posted on Sep 25, 2008
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Anonymous
  • 10865 Answers
  • Posted on Aug 16, 2009
SOURCE: 25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Oct 05, 2009
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Bosse Photos
  • 232 Answers
  • Posted on Nov 13, 2013
SOURCE: I have a Frigidaire Gallery 27.8 Cu. Ft. French
This is a manufacturer issue that needs to be addressed by the company who sold or made it. Phone:
1 (800) 374-4432
Monday - Saturday
8:00 a.m. - 8:00 p.m. (EST)
This is their number. Call them first. It is a good company. I myself have their products. Let me know.
Ice maker will not crush ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Crushed ice is the default position and the solenoid is energized to cube ice.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
I have a Frigidaire FRS23H5ASB9 side-by-side. The "cube" button works, but only crushed comes out. "Crushed" button works fine, too, but we usually want cubes. What's causing this? Is it the dispenser or...
most likely the solinoid is frozen or bad.. pull ice bin, the metal lever on back of bin fits in solinoid in freezer see if you can move plastic piece in freezer with finger.
Icemaker is on cube but is still crushing ice it seems like it is stuck on crush,the light is on cube.
Icemaker only dispenses crushed ice
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
3helpful
Dispenses crushed ice and will not dispense ice cubes
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
hi there,
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
