You must make certain the "source" setting (button on the side of the television) is set to "TV".
It CAN NOT be set to Componant, AV, HDMI or any other input source to be able to open the "Channel" menu.
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
SOURCE: Need menu control
On some tv's holding down one or two of the buttons on the front of the tv for a few seconds will bring up the menu. If it comes up you can probably navigate in the menu with the buttons on the front of the tv.
SOURCE: my frien change my passcode on my lg voyager an now i cant unlock
go on to l.g web site register and customer services should help u
SOURCE: I need to do a
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
SOURCE: I have a TruFlat RCA
Try this -
Regards,
Tony
