Question about Hammering
I have a Workzone titanium Demolition Breaker purchased at Aldi. About to use but not sure how to check/know if enough oil in it or how to add oil.
  • 2,013 Answers
In most brands of this breakers there is no oil used , (only if there is an oil sight glass on it) some rotary hammers or breakers with high rpm have oil lubrication ( in most case its a sinc free hydraulic oil) (or special Turmopol oil (by Hilti) but this kind of hammers have no high rpm for oil and i think its having a normal grease lubrication and its enough for replace the grease after the carbon brushes are short and the tool stopped working then its time for service o-rings and seals and grease for the next service by the ALdi service.??
Posted on Dec 02, 2019
3 Suggested Answers
6ya staff
SOURCE:
Editor925
Dean
  • 285 Answers
SOURCE: what type of oil i will luricate to my makita HM
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
Posted on Feb 25, 2010
angusmeads
Angus Meads
SOURCE: Which oil should be use in a demolition breaker hammer
Hydraulic
Posted on May 16, 2017
Where can I get 8x11.3x2mm staples for an Aldi Workzone Staple Gun
8mm = .315" rounded to 5/16"
11mm = .445" rounded to 7/16"
2mm = .079" rounded to 5/64"
5/16 x 7/16 x 5/64 staples...
Jun 01, 2017 | Staples Tools & Hardware - Others
How to lubricate electric demolition hammer
Only lubricate is not enough,the kind of grease is brand and breaker type dependent , but a consumables kit and a condition that the machine that front that the striking pin in the front air and lubricant is closed in terms of oil seals etc completely closed has very high priority otherwise it is only momentary, because all O-rings, etc. are to fast getting hot again a rapid solidification and its leaking again , and premature all kinds of rings are hardened again, therefore there must be a service (maintenance kit (spare parts) are used A NOTE a rotary hammer is not a demolition hammer and there is often more wrong with and most times too expensive to service in proportion to hidden defects with respect to the new price it than a heavy breaker
May 26, 2014 | Hammering
How to put oil in Hitachi H65
OIL ?? I think Hitachi has always a yellow grease lubrication
hitachi grease demolition hammer Google zoeken never seen heart of oil in Hitachi demolitions. but there could be models in your Country thats new for me .
Otherwise BOSCH HILTI and the one and only brand DUSS demolition hammers and also a few brands of Chinese hammers need oil lubrication . an expensive sinc-free hydraulic oil the same as used in some pressure washers life lasting oil but for HItachi look at the link for the grease 2 tubes a enough . good luck and dont forget the piston pin to replace with a new not only the gaskets and o-rings and also the oil and dirt seals on the front where the striking pin is that must be absolutely not air leaking because all your work burns in a few months again out . you can start all-over again.
May 15, 2014 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
OIL FOR JACKHAMMERS
There is a sight glass on the side for you to see the oil level. Make sure they are always checked. You can buy the oil at any service center. Hilti makes oil too and can probably be purchased at Home Depots. Also the Home Depots that have tool rental programs would most likely sell the Hitachi oil too.
Dec 22, 2011 | Hitachi Hammering
Need manual for delta ultrasonic cleaner.....not in box when purchased from aldi
Hi.
Here all the documentation available on the web. If this is not enough contact Aldi to get a replacement booklet:
Model: 334.150
Data Sheet
Catalog Page
Model: 334.D80H
Data Sheet
Model: 334.010
Catalog Page
Data Sheet
Model: 334.080
Data Sheet
Catalog Page
Jun 10, 2011 | Vacuums
What type of oil i will luricate to my makita HM demolition breaker
Feb 25, 2010 | Makita Hm1500b 42-pound Demolition...
Hammering Logo
54 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Hammering Expert? Answer questions, earn points and help others
