Question about LG Televison & Video
I have a lg 50pj350r tv that keeps saying the antenna isn't connected when trying to scan for channels.. what can be the issue?
    Habit-Forming:
  • 22 Answers
Possibly a bad connection on the antenna jack on tv. Does it wiggle at all? TVs have to be made so cheap these days because us consumers buy the cheapest products. The antenna jack or f connector is sometime only held on by the solder that area he's it to the circuit board. When the tv gets move 4 ft and there is a 3 ft coax cable, the f conn solder will break. Sometimes it is easy to resolder if you are a little handy and are qualified to disassemble the tv. Otherwise if you use sat or cable you can bypass this issue by using the hdmi on the receiver to tv and get your local channels thru sat or cable
Posted on Oct 02, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Posted on Nov 21, 2008
Anonymous
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
dave1645
Dave Naylor
  • 834 Answers
SOURCE: Vizio l37
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Posted on Nov 03, 2009
dvdcdlaser
Dvdcdlaser
  • 1285 Answers
SOURCE: my tv wont pick up any channels
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Posted on Jul 26, 2010
Falling star
  • 216 Answers
SOURCE: my tv just stopped getting antenna reception today.
your anntena may be set to cable rather than to AIR. check the setting on the TV to verify it isnt set to cable when you are using an over the air antenna. also it may be the input, if you are using coaxial for the input say #1 and it is acutally on #2 then you may need to change the input. Since I didn't see a brand of TV I cant walk you through it. ALso there is a TV/video button try hitting it one time on the remote. if all fails then unplug the tv for 30 minutes and try setting it up again.
Posted on Nov 09, 2011
Hooked up antenna its says choose antenna and scan i do that it scans and nothing keeps saying choose and scan please help wife is on my. to fix help
Your choices usually are cable with/without digital channels and Cable with / without digital channels. Once you choose which tuner the TV will use, then it will autoscan for channels.
Aug 10, 2016 | Televison & Video
I have a flat screen TV and i got the digital channels but I did something and now i can't get any digital. Please help me.Thanks
Well im not an expert on this but by wife keeps deleting channels... you can just go to setting and anything the reads channel search or digital search just run it or scan... your tv will scan all channels... make sure that your antenna is connected or digital receiver... when you tv searches it needs something connected to the input of the tv antenna... you can try goggling it too
Apr 27, 2016 | Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
My Westinghouse W3223 television occassionally loses channel 4-1. I don't mean can't find a signal, but it completely disappears from the TV. Not in the mannual channel select menu, no where to be found....
This problems is alway the airial positions of the antena work for some tv not for other.Because of wrong poistion tv or wrong antena position reception could work for one tv don't work for another tv.Buy another tv antena used for that tv for it alone will solved this problems.
Jan 09, 2011 | Televison & Video
This tv is not connected to cable or dish, but has an interior antenna. up to about 2 months ago, we could get network channels (abc, nbc,cbs) which is all we wanted. Suddenly CBS dropped out, says "no...
How far away is the CBS station? Are there any obstacles that would block the signal (say new construction)?
What channels do antennaweb.org or tvfool.com suggest you will get from your location? (Antennaweb is more conservative and assumes an outdoor antenna.) Do you need to rotate your antenna to get one transmitter or the other? Indoor antennas are more likely to get interference and direction issues.
You may want to restore your TV to the default and then rescan the channels. (This may or may not help. It usually helps more with scrambled information than lost channels.)
I hope this helps.
(good luck. I've had issues with my CBS and Fox affiliates (sharing a transmitter location). At first it was clearly my TV and the reset helped. Now I have no clue as to the cause - the external TV antenna gives a strong signal on the other TV. The problem TV says the signal is bad and this is the closest transmitter and antennaweb says I should get it easily. Even pointing the antenna straight at the transmitter doesn't help.)
Jun 10, 2010 | Element Electronics FLX1511B 15 in. LCD TV
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
Describe how to program channels on lg tv
Very simple -
You will need to find a feature that says 'Auto Tune'
This first will ask you to select between:
1) Regular TV - off air antenna - connection
2) Cable TV - connection
3) DSS TV - Connection
If you aren't ready for digital TV with your antenna or cable you may get very few channels.
Nov 17, 2009 | LG 42LC2D 42 in. LCD HDTV
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Dec 07, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
107 people viewed this question
Ekse
RONALD CARTER JR
