Just fills then nothing ???
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
SOURCE: how do you open the front cover for Kenmore front loader 110.42926200
Sure thing, under the door is a kick panel, held on by three hex screws,standard uses 1/4 inch and torx uses a 9/32 socket. A slight down tug will loosen the panel and behind that you will see the pump at right front. Just to the left is a round soda can shaped housing with a large turn screw lid attached to the pump. Grab a bucket and some towels, unscrew the lid like a jar of peanut butter slowly to let the water into the bucket. This may require two trips and some getting wert. The trap is attached and easy to clean. Next reach behind a gently shake the black boot joining the tub to the pump for coins and lint. The last item is getting a bright light and inspecting the pump through the small hole right side that can be seen once the trap is removed. Check for debris then put a finger in the hole and check the impeller for disconnection from debris/
SOURCE: kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
SOURCE: Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
SOURCE: Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
