What codes are for your tv that will work with tivo
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
They should have a special website designed especially for codes for remotes and T.Vs lets make it happen somehow!!!! Thank you! :)
I have a trisonic ts-rc488 and i lost the manual to prongram the tv i have a symphonic
But i have a comcast remote for it
0008
I m need code for tv samsung
thanks
I need a code to unlock my playboy channel
I have a Toshiba Big Screen need codes for remote ufc3110
I am using a philips universal remote for a emerson tv
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1) From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
I need a code so my Tivo remote will work the power and volume...
I'm using a Zenith C32V37 now and my DirecTiVo remote will only turn the TV on and off using code 0070. I can't get volume or input to work.
Surely there's a fix for this by now.
PC29Z58
I HAVE A BIG PROBLEM I NEED TO GET KEYZ FOR MY DISH BUT I CAN NOT GET THEM FOR FREE PLEASE FIND A SITE THANK
YOU
i need the code for a duraband
