Apple iPhone Smartphone Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IPhone camera stopped working
I have an older iPhone. My camera recently stopped working. I've reset, restarted and updated... Nothing's worked yet. I press the camera widget and the shutter appears, closed, and the button that takes the photo is greyed out. Please help! Thanks :)
August Brown
Level 3:
Genius:
  • Apple Master 1,652 Answers
  • Posted on Jun 15, 2021
August Brown
Apple Master
Level 3:
Genius:
Answers
1652
Questions
0
Helped
352149
Points
5096
Try to change to front camera to see whether the front camera works. If it works, you may consider it's a hardware issue of the rear camera. If it is still not working, you may consider it's the issue of the camera app. If so, try to download third-party apps on App Store. If it is a hardware issue, it's better to contact Apple: https://www.apple.com/contact/ for further help. After repairing, here are some iPhone camera tips and tricks FYI: https://all-things-about-apple.blogspot.com/2021/05/10-best-hidden-iphone-camera-tips-tricks.html
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 27, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
530
Points
0
My iPhone camera stopped working.i press the cam widget and the shutter appears closed.
2answers
Iphone 6 camera not responding to touch
Hi Sheila
If you have tried the Full Reset
Hold Home and top Side button down for 15 seconds
Shuts down
Top side button to restart
if that Fails you need to drop int an Apple Shop - book first
or mail it in
Good luck
iPhone 6 How to Hard Reset Reboot No iTunes Lost Password or Disabled
Many More tutorials
iphone 6 reset without password YouTube
Camera is not working
How to Fix the iOS 11 Camera Not Working
1. Close the Camera App completely.
If you find problems with the iOS 11 camera app during usage, close the app from the App Switcher and then open it again.
For most iPhone models that have a Home button, to completely close the camera app, double tap the Home button to bring out the App Switcher, and then swipe the Camera app up to close it completely.
For iPhone X users, swipe up from the bottom of the screen and pause in the center of the screen to open the App Switcher, and the press and hold the Camera app until there's a Close button on the app, then you can tap on the button or swipe up to completely shut down the camera.
2. Restart your iPhone.
Sometimes small issues like app crashes could be fixed by simply rebooting your iPhone. It's a common solution for a lot of bugs and errors on iPhone and a lot of other electronic products. So when you find an iOS 11 camera bug, instead of getting frustrated, try restarting your iPhone first and see if it gets back to normal.
Press and hold the Power button on your iPhone until the Slide to Power Off bar appear. Slide to turn off your iPhone and then press the Power button again after it's been completely shut down to turn it back on.
To turn off iPhone X, press and hold the Side button and one of the Volume buttons at the same time. And then the Slide to Power Off bar would appear.
3. Reset iPhone Settings
If restarting your iPhone doesn't work, try resetting all the settings on your iPhone. It will only reset the system settings and won't damage your person data like photos and messages.
Go to Settings>General>Reset and tap on Reset All Settings.
4. Check for new iOS Updates
Usually if there's a bug in the old version, Apple would have the bug fixed in the latest update. So check and see if there's any update available and update immediately when you can.
Go to Settings>General>Software Update to check for the latest update.
5. Check if you have run out of storage space
One possible reason why you can't take a picture with your camera is that you may have used up your storage space and there's none left for more photos. Go check and see if that's the reason.
Go to Settings>About>Available and see how much space is left on your iPhone.
For more details, check: iOS 11 Camera Not Working:How to Fix
Iphone stuck on itunes screen with usb
First power off your iphone and restart it does it start normally or not.
Secondly restart your iphone without connecting to computer. so remove usb cable and restart your iphone ipod or ipad. Even though iphone stuck all logo and itunes and usb symbol then it is a issue of original sim
Secondly when you connect iphone to computer and it detected as recovery mode then your ipod iphone is not properly restored. Here is how to restore ipod / iphone or ipad.
Bluetooth won't connect
I'm going to assume..you've got an iPhone.. Simply because apple seems to have a "list" of approved blue-tooth items.
Unless your "JailBroken" (google only, please do not ask), if the said bluetooth device will not connect, consider updating your iOS to 5.1.1. or 6.0, or simply deal witht thefact..it won't work... Older deviices (3gs and prior) don't support things like A2DP (blue-tooth bi-direction communication, like a head-set)... and unless (jailbroken..see above about google). will simply not work.
If your NOT talking about an iPhone..you've got me.
Apr 08, 2012 • iPhone Apps
Iphone wont connect to wifi
1. Reboot the routers and it should work after that.
2. Reset Iphone network settings
3. Update to a more recent version of the software
4. Restore Iphone from Itunes
After i leave the main screen and go to lets just say text msgs....when i want to go back to main screen it will not allow me to go...seems like it freezes on current screen...
First you have to restart the phone and the reset it.Beacause the apple ios is corrupted you have reset the ios to work properly.When you reset the apple i phone new Ios will be re-installed it will not update it will only reinstall so the firmware will work properly.
To restart iPhone running iOS 3.0 or later
1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button.
2. Instead of dragging the red slider, press and hold the Home button for six seconds.
3. If the device does not return to the Home screen, see the steps below to restart.
To restart iPhone iOS 2.2.1 or earlier
1. Press and hold the Home button for six seconds.
2. If the device does not return to the Home screen, see the steps below to restart.
If the iPhone touch remains unresponsive, try restarting the device:
Restarting iPhone :
1. To turn it off, press and hold the Sleep/Wake button until the red slider appears.
2. Slide your finger across the slider to turn off iPhone.
3. To turn iPhone touch on, press and hold the Sleep/Wake button until the Apple logo appears.
Resetting the iPhone:
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
If still the problem persist you have to update the firmware:
Updating and Restoring iPhone Software
You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
1. Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2. Connect iPhone to your computer.
3. In iTunes, select iPhone in the Source pane and click the Summary tab.
4. Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available.
5. Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
3answers
Hi, How can I fix an Iphone 3gs camera, it says camera module not ready?
Cheapest way is to do it yourself and camera module is easily accessible. If Apple doesn't replace it for you, you can find the camera module at iPhone 3GS Repair and there is a guide that shows you how to put in the part at iPhone Repair Guide.
IPhone accessory problem
When the iPhone loses power while playing a song, there was a bug in older firmware that caused all audio to be usable through the speaker only. The solution is to stop the song before you undock the iPhone - or, update your iPhone firmware to the latest.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
