SOURCE: kenmore elite he3 electric dryer
If you get a series of four rapid beeps when you push START in an attempt to start your dryer, your door switch (interlock) is defective. I have experienced this problem before and it is a fairly simple problem to fix. The easiest way to tell is to open the dryer door and push the door interlock in by hand. Hold it in while pushing the START button. If the dryer starts, then all you have is a simple problem of the door not closing properly. If the dryer still does not start, however, replace the dryer door interlock. The interlock should also make a definite "click" while pushing it in. If it does not, the switch is worn out. Some dryers have an upper and lower door interlock. If yours is equipped with two interlocks, make sure they are both functioning and that the door is latched properly. I have experienced problems where dryers doors with two interlocks would close at the top, but not at the bottom. The dryer would not start as a result. If you can provide me with your model number I can get a part number and price for you. I can also tell you where you can get the part and provide instructions on how to replace it. Let me know. I hope this helps you.
SOURCE: whirlpool dryer
1) sounds like that accudry sensor needs checking. If the accudry sensor (the back box with the two silver trips in it under the lint filter) does not sense wet garment it coul cause the dry to start and then cut off or not start at all. did you try using a cycle that does not sense the load you are dying. 2) the mother board of the dry may need chnaging depening on your dryer. if your dryer is like the cabrio, duet or the senseon dryer then it could be a motherboard problem.
SOURCE: 3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
SOURCE: Whirlpool Cabrio Dryer Wont go past sensing light
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
