Hitachi 36UX01S 36" TV Logo
Posted on Sep 16, 2009
Sound only w/1 straight red line accross the middle of the screen
TV was working fine. Tried to turn it one one morning and it has a thin straight red line across center of screen. TV is a Hitachi Ultravision 40"
Anonymous
Level 1:
  • Contributor 71 Answers
  • Posted on Sep 16, 2009
Anonymous
Contributor
Level 1:
Answers
71
Questions
0
Helped
10736
Points
95
Try to replace the vertical ic and resolder the vertical section.
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
6helpful
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
2answers
Bad picture on Toshiba
this is a malfunction vertical deflection block of your TV-set .please contact the nearest repair shop.do not turn it on until then,please.
1helpful
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
2answers
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
2answers
Apex 51 inch projection model gb5108
I have worked on projection displays for about 17 years 20years electronic. and this sounds like a vertical deflection amplifier problem. this is if the lines or the rainbow you said that you see are horizantal.
Quasar sp2722 27 tv
you have an intermittent vertical ic or caps . it will need service sorry usually it's not to expensive werepair these all the time
APEX TV problems
need flyback transformer #030531-5283
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
