SOURCE: washer does nothing when you pull the button to start
It is probably the lid switch. On some machines there is a lid switch fuse that may not be in your wiring diagram for your machine.
Some of the fuses are glass and look like an automotive fuse and there are some enclosed in the switch assembly that you can't see unless you drill out the rivets holding the switch together.
It is a carbon fuse with a spring on each end pulling on it.
I had the same problem with mine and Maytag tech told me there was not a fuse in the switch.
This made troubleshooting especially frustrating.
