Question about GE Washing Machines
Ge wssh300g0ww front load washer start light flashing
I have an older wssh300g0ww front load washer. When I hit start twice, the lock light and start light light solid and I hear the door lock. After a second or two, the start light starts flashing and the lock wash rinse and spin lights light up. the control lock light is NOT lit. I tried a new locking mechanism and I tried resetting and unplugging for 5 min, nothing is working. What can I try next? Steve
    Top Expert:
  • GE Master
  • 10,627 Answers
Possible water inlet plugged or solenoid bad
Posted on Sep 28, 2019
6ya staff
SOURCE:
the dr
joey shearer
  • 447 Answers
SOURCE: control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Posted on Jan 01, 2008
Anonymous
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Posted on Apr 27, 2008
Anonymous
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
Anonymous
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
mp10257
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
Solid red light after installation of battery and setup of crank. Door locks twice when hit lock button
The bolt might not be lined up correctly. It needs to operate freely. Make sure bolt operates smoothly with key and turn button .
Jul 15, 2014 | Weiser Lock Locks & Locksmithing
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
When I try to use the washer I press the Express Wash Cycle as usual. The panel lights up as usual but when I press the start button it dosen't start. I don't hear the front load door lock as usual and...
'F' for fault, 'dL' for door lock and you don't hear it operating. It's pretty clear there is a problem either with the lock operating solenoid (highly likely 'cos you don't hear it operate) or the door lock sensor (not so likely).
Either you need to replace it or it needs replacing by a service engineer. Sorry, no other option ;-0(
Good luck,
John C
Mar 04, 2011 | Kenmore Elite 45986 Front Load Washer
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Front load will not lock
are you getting three beeps when trying to start, if so door lock problem
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
48 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
