Televison & Video Logo
D
Delia J. Fry Posted on Sep 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG DVD dp132h hooked up to Seiki tv model #SC262F both turn on but dvd only opens and ejects dvd
Tom Chichester
Level 3:
Top Expert:
  • LG Master 62,329 Answers
  • Posted on Dec 11, 2020
Tom Chichester
LG Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672473
Points
975369
Some DVD players operate that way initially.
5 Related Answers
A
Anonymous
  • Posted on Jul 17, 2008
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Anonymous
  • 298 Answers
  • Posted on Apr 20, 2009
SOURCE: my LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Anonymous
  • Posted on Apr 24, 2009
SOURCE: Fault Ecplipse car DVD
well i have one of the same player and i have the DVD software but its the only one i have and I'm in Jamaica.my email address is [email protected].
Anonymous
  • Posted on May 22, 2009
SOURCE: dvd tray will not stay closed. opens and shuts randomly
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.9acead3.jpg
Anonymous
  • 111 Answers
  • Posted on Feb 03, 2010
SOURCE: There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Testimonial: "Thanks a lot! It worked. Now I'm afraid to use the DVD player. Maybe I'll put in an old kid movie that we don't watch anymore and see if it works. "
I have a LG DP132H-NU AUSALLA DVD/CD Player July 2022. HOW DO I CHANGE REGION CODE?
To change the region code on your LG DP132H-NU DVD/CD player, you will need to follow these steps:
  1. Turn off the DVD/CD player and unplug it from the power outlet.
  2. Press and hold the "Stop" button on the player.
  3. While still holding the "Stop" button, plug the player back in and turn it on.
  4. When the player powers on, the region code will be displayed on the screen.
  5. Use the "Up" or "Down" arrow buttons on the player to select the desired region code.
  6. Press the "Enter" button to confirm the new region code.
  7. Turn off the DVD/CD player and unplug it again.
  8. Plug the player back in and turn it on. The new region code should now be in effect.
Keep in mind that most DVD/CD players are only designed to play DVDs and CDs that are encoded for the region in which they were purchased. If you try to play a DVD or CD that is encoded for a different region, it may not work properly or may not work at all.
JUST GOT THIS HOOKED UP THIS MORNING,NICE TV.ANYWAY NEED TO HOOK UP MY DVD PLAYER NO VIDEO BUTTON TO CHANCE FROM TV TO DVD WHATS UP? MOVIES WILL NOT PLAY
input source button and what input did you stick the DVD player into was it HDMI1 port cause if it was you would change input source to HDMI1 from DTV input source.
on the tv you have the remote control it has a source button just left of the channel up and down + ch - buttons.
2answers
Lg dp132h change the region code
Press setup on your remote and choose the lock symbol. Then go to area code and right click arrow on remote. Password should come up and put 0000 press ok. You will then be able to change the region for example Great Britain is GB. I've yet to test this out due the fact I don't have a corresponding DVD but if it works for you post your results. I'd love to be able to buy my favorite sci-fi shows no longer in US print.
We have a brand new LG TV with a built in DVD player. We put in a DVD and the message was "No Signal." DVD will not play. I cannot eject it from the player
Hi:
The only way to diagnose this problem is to take the DVD out and inspect the take up rollers designed to take and eject the disc. If you hear sound when try to eject you may have a bad belt or the take up rollers are oxcided causing slipage during ejecting.
2answers
DVD don't load
dvd mechanism needs to be replaced. LG is a good brand.
9helpful
Cant eject DVD's
Unplug the player and leave it off for an hour then plug it and press EJECT or OPEN/CLOSE continously until it releases the disk.
2helpful
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
