Question about Kenwood KDC-135 CD Player
Aux out put
Once i plug in my MP3 player how to i switch so my stereo plays it?
  • 106 Answers
Press the src "source" button untill it comes up aux mode, you may have to go into another settings menu to activate the auxiliary inputs on the headunit
Posted on Sep 16, 2009
6ya staff
SOURCE:
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
How do I get the MP3 player to work in a 2007 Nissan Quest?
you said CAN , i bet you meant CAN'T or CAN NOT. right?
the AUX port is just a line input, analog audio input,
it dont know MP3 .
it only amplies the analog audio found there.
you connect any device, to AUX. push play on the device.
then put car radio in to AUX input mode and play. the audio.
that is all there is to it.
the external device does all the heavy lifting, reading a file, and decoding it (mp3 decode) and then sends raw analog audio out.
the cable is sold and radioshack, or walfart or many other stores,
Target, most MP3 players, come with this cable,
they use mini phone plugs, stereo, type,. (3 contacts)
Jul 05, 2014 | 2007 Nissan Quest 3.5 Minivan
How to connect mp3 player to stereo
connect the audio lead into the head phone socket on the MP3 player and the other end of this audio lead into the Line in/Aux input on your stereo.
Switch the stereo to Line in/Aux and then turn on the MP3 plater.
Apr 09, 2012 | Computers & Internet
Ok...I have an Alpine CDE-9845 and i wish to play my ipod by using an aux cord but i have no clue where to plug it in at
You will first need an audio cable that has a 3.5mm male end on both sides of the cable.
You will plug in one end into your mp3 player, and the other end into the 3.5mm audio jack on the front of your cd player. On rare occasions its on the back of the cd player.
Then instead of putting your cd player on the radio, or cd, the other option will be Aux. Start your mp3 player up and you should be able to hear it on your car audio system.
This is the standard setup for running an mp3 player through your car stereo. Thank you for choosing Fixya!
-Daniel
Aug 10, 2010 | Alpine CDE-9845 CD Player
Playing MP3 Via AUX comes out crackly
Try turning the volume lowwer on the mp3 player and higher on the head unit. The radio is trying to amplify an amplified sound which is why you are getting distortion.
Mar 22, 2010 | Car Audio & Video
There is a auxiliary button on the sony cdx-m8800. Is there a way to hook up an IPOD? The stereo also has MP3 written on the inside face. Thanks
Contrary to the below Expert's testimony, the UK CDX-M880 has a REAR AUX connector that will enable you to play your iPod through your car's stereo.
You will not be able to control the ipod's interface through the radio. You will have to use the control on the iPod .
You require a Male 3.5mm extension cable like the following...
a5e60c6.jpg A 4-6 foot length is recommended, as the cable will need to be routed from behind the radio to a place your iPod can be easily manipulated.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 18, 2009 | Sony CDX-M8800 CD Player
I cant figure out how to get an MP3 player to play through my CD player....it has 3 different audio rca jacks in the back...i try all three none worked....is there an AUX setting that need to put my cd...
what kind of cd player do you have? you must make sure that your unit has auxillary inputs. some decks dont have them. if it is set up with aux input rca's, then you just connect those to the mp3 player, then you should be able to play it in the aux mode on the deck. if you cant find it by hitting the source button, then you may not have it. I know on my sony stereo, I actually had to turn the deck off with the ignition switch on. then I press the menu button, and there I can toggle the aux mode on or off. if that doesnt work either, then you either dont have aux inputs, or the inputs are bad on the stereo, meaning its not gonna work at all.
Jul 28, 2009 | Car Audio & Video
Can I plug my MP3 player into the aux. socket on my car radio, with the appropriate cable and play the stored music?
You should be able to do that as long as you have the right cable.
Most of the mp3 players have a "mini-stereo" jack (3.5mm) and some car stereos have the same type of jack for "aux" input, and others car stereos have RCA jacks for the "aux" input.
Even if the jacks are not the same type, you can use an adapter cable that converts the mini-stereo jack to an RCA jack. You can find them at many places like Best Buy, Circuit City or Radio Shack.
Depending on the type of car stereo you have, you would normally press the source button to change between the tuner, cd player, aux or whatever you may have connected to the stereo. You may even have a seperate button to press for the "aux" input.
I hope this was helpful to you, if you need more information just ask, and please give more info on the type of mp3 player and the make and model number of the car stereo.
Jun 21, 2008 | Car Audio & Video
MP3 player over my car speakers?
Try from both ports on your Insignia and make sure you've turned the volume on it all the way up. On the car stereo, make sure the source is set it auxiliary (usually AUX-IN). Also double check your cord isn't damaged and plugged in all the way on both sides.
Apr 13, 2008 | Insignia NS-DV2G MP3 Player
Does not switch to Ext Input
You have to enable "Line in" in the Stereo menu. Once you enable it when you press CD/CD-CH it should change to "Line In" and display Line in on the screen. Check the manual on how to enable line in...
Jan 30, 2008 | JVC Sirius KD-LH300 CD Player
Kenwood KDC-135 CD Player Logo
27,098 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
