Question about Canon Cameras
Downloading an updated Firmware for Canon 5D Mark II
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
The current firmware is version 2.1.2. Use this link to get to the Canon download page. Scroll all the way down to “Drivers and Downloads”. Select “Firmware” and then the appropriate version for Windows or Mac.
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/support-dslr/eos-5d-mark-ii?subtab=downloads-firmware
Posted on Oct 26, 2019
    Top Expert:
  • Canon Master
  • 55,370 Answers
Contact Canon directly to inquire.
Posted on Sep 29, 2019
6ya staff
SOURCE:
Ty Price
  • 11967 Answers
SOURCE: how do you remove LCD cover on canon 5D mark II.
Google the words...disassemble a digital camera.
Posted on Oct 16, 2009
SOURCE: canon imageclass mf5770 firmware update
you need to check canon website
Posted on Dec 15, 2009
Obertelli
Obertelli
  • 3006 Answers
SOURCE: I mounted the Canon 580EX II to my Canon 5D Mark
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
Posted on May 24, 2010
tinualbinale
TINU ALBIN ALEX
  • 436 Answers
SOURCE: The language on my Canon
Follow the correct instructions below based on the diagram to change the language of Canon EOS 5D Mark II from Japanese to English;
1.Press the MENU button.Different tabs are displayed on top of the screen as shown below.
2.Turn the Main Dial to select the tinualbinale_33.png Setup Tab ( The one with two dots and a spanner) on top of the screen.
3.Under this tab Turn the Quick Control Dial to select [Language] ( the third item from the top ) and press the SET button.
4.To select the desired language use Main Dial or Quick Control Dial (The current setting is indicated in Blue) and Press the SET button.
5.The desired language is set.
Thanks for choosing Fixya
Posted on Jun 20, 2011
  • 102366 Answers
SOURCE: Looking for directions on using
Press the [AF-DRIVE] button and select the self-timer mode. Point the remote controller toward the camera and press the button.
Full details are in the "Remote Control Shooting" section of the camera manual (page 102 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/0/0300004270/01/eos5dmkii-im4-en.pdf
Posted on Jul 20, 2011
Canon 5D Mark II error 80
Error Code 80 on the 5D II indicates the a
Malfunction related to the electric control of images has been detected.
Apr 18, 2014 | Canon EOS 5D Mark II Digital Camera
Tip
1080p MOV Conversion-Import/Edit Canon 5D Mark II MOV to FCP X with ProRes...
1080p MOV Converter-Transcode/Edit Canon EOS 5D Mark II 1080p MOV to ProRes 422 for FCP X <br /><br />Canon EOS 5D Mark II is one of the best DLSR made by Canon. It shoots full HD 1920x1080p videos in MOV format. However, with the high quality MOV videos, you may find that the log and transfer method on FCP X does not work for them .Therefore, In order to edit the videos of Canon EOS 5D Mark II, <b><a href="http://www.aunsoft.com/video-converter-mac/">1080p MOV Conversion for FCP X</a></b> is necessary. I googled and found Aunsoft Video Converter for Mac as the perfect. <br /><br />How to <b><a href="http://1080p-converter.com/2011/07/top-notch-mac-camcorder-conversion-tool-convert-canon-5d-mark-ii-mov-to-prores-for-fcp-x-editing/">Import and Edit Canon EOS 5D Mark II MOV to FCP X</a></b>? <br /><br />1. Transfer Canon EOS 5D Mark II MOV to Mac <br />Connect Canon EOS 5D Mark II DLSR to Mac with a USB cable. Copy the MOV files to hard drive on Mac or from outside. The MOV videos will be soon transferred to Mac computer. <br /><br />2. Load 5D Mark II videos to Aunsoft Video Converter for Mac <br />Run Aunsoft Video Converter for Mac as the <b><a href="http://www.aunsoft.com/video-converter-mac/">Top-notch Mac Camcorder conversion tool</a></b>. Click the "Add" button to load the MOV videos to the program. <br /><br />3. Choose output format and destination <br />Click the "format" option, and choose Final Cut Pro &gt; Apple ProRes 422(HQ) (*mov) as the output format. Click the "Browse" button to specify the output destination. <br /> <br />4. Convert 5D Mark II MOV videos to ProRes 422 for FCP X <br />After the output format and destination are set, click the convert button under the preview window, wait just a few minutes and the converted Video from <b><a href="http://www.aunsoft.com/video-converter-mac/">Canon EOS 5D Mark II MOV Videos to ProRes 422</a></b> will be ready for you to edit on FCP X. <br /><br /><b>Tips:</b> <br />Aunsoft Video Converter for Mac can also convert videos for other softwares like <b>iMovie, Adobe Premiere Pro, Final Cut Express (FCE)</b> and various media devices like <b>iPhone 4</b>, <b>iPad </b>and <b>Motorola XOOM</b>.
on Jul 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Canon EOS 5D Mark II digital camera Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Canon's official website.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
on Mar 07, 2010 | Canon EOS 5D Mark II Digital Camera
Cannon EOS 5d mark 3....it is in another language...how do you change it to English. I see the answer for mark 2 but this doesnt work on mark 3?
I was able to download the manual from Canon USA for free. I could search the page for you, but perhaps you also want the manual and read it yourself? here is the link to the download page:
EOS 5D Mark III
Oct 21, 2013 | Canon EOS 5D Mark II Digital Camera
My canon 5d mark II won't format memory cards. It keeps asking me to format, and then telling me it cant format that card and to switch it out. I've tried 3 different cards, none of which have ever been ...
I've encountered this problem with a 5D Mark II and the problem was the card. Our card was a 16GB Sandisk Extreme that was just as new as the camera. Make sure your camera's firmware is up to date. If your card is high in GB your camera will have a hard time poring with it if the firmware is old. But as we figured out, our card was bad, plain and simple.
Feb 05, 2011 | Canon EOS 5D Mark II Digital Camera
Photos taken with canon 5d with both raw & jpeg formats. When I open Adobe bridge the photos are displayed as _mg_0133.cr2 and _mg_0133.jpeg. The jpegs can be viewed and opened, but I can't open the cr2...
If you have the 5D Mark II (the latest version,) the raw converter in Photoshop CS3 does not support the format. If you have the earlier version of lthe 5D, download the latest raw converter update from Adobe (free}
If you have the Mark II you can do one of three things to continue using Photoshop:
1. Upgrade to CS4. The latest update for it's raw converter supports the 5D Mark II.
2. Download the Adobe DNG Converter when 5.2 version becomes available and convert your cr2 files to the DNG format which CS3 can read. In the past this has been available as a free download form Adobe, but it's not currently on their site.
3. Use the raw converter that came with your camera.
Dec 23, 2008 | Adobe Computers & Internet
Cameras Logo
60 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
