Question about RCA Televison & Video
Trying to connect fire stick to rca RLDED3956A and the fire st is not starting. I have unplugged the power and removed and replaced into the appropriate HDMI port. any suggestions?
6ya staff
SOURCE:
RescueTechLA
RescueTechLA
  • 2653 Answers
SOURCE: ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Posted on Mar 02, 2009
Anonymous
  • 53 Answers
SOURCE: Samsung WS32Z40 Problem connecting HDMI to HDMII
I will assume it a display resolution issue. Try to set your laptop display at resolution 1280x720 or 1920x1080, as this will be the max res. for that tv.
give it a try and let me know about the outcome.
Posted on Mar 24, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: connecting a laptop to a tv
You have to tell the laptop to use an external display this usually involves pressing the FN + F5 on and acer but does vary from laptop to laptop
the second key usually has two screens printed on it
Posted on Dec 31, 2009
MalKontent68
Stan
  • 748 Answers
SOURCE: i TRIED TO CONNECT MY LAPTOP TO AN HD TV VIA THE HDMI PORT
Most probably it will be enough to press Fn + F5 to change the display output. Pressing this combination sequentially toggles between 3 settings usually:
Internal LCD
External output
LCD and external simultaneously.
The external-only option is the best, as it will give you an option to set a screen resolution suitable/optimum for your TV, as oposed to the resolution of your internal LCD display, which is optimum for your display, but doesn't use the full capabilities of your TV.
Good luck, and please come back with a testimonial/rating if helped.
Posted on Jul 23, 2010
spr1949
Parasuraman S
  • 1182 Answers
SOURCE: suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Posted on Jul 29, 2012
Turn off audio for visual impaired on rca model rlded3956a
Return to the initial set up procedure and disable the second audio program (SAP).
Apr 01, 2018 | RCA Televison & Video
Picture goes off and on
Please turn off your TV for about 3 hours, please unplug the power cable. That will reset it back to normal.
Aug 24, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Tip
Amazon fire stick reset
make sure that your wifi is a good signal,if you are using a lower tier internet service then it wont work,call your internet provider and verify that your internet is sufficient,also use 5ghz wifi,not 2.8ghz.
if this doesnt work for connecting then,
reset this way,
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
also,xfinity remote controls work with firestik tv in place of the original remote,program it for a vizio tv and forget the original remote!
on Apr 03, 2015 | Amazon Fire TV Stick
My fire stick is not connecting to internet and I know my internet is working
hi Paula.
not sure if this will help you out.
To restart your Fire TV: Unplug the power adapter for three seconds, then plug it back in. You can also restart your device with your remote. Press and hold the Select and Play/Pause buttons at the same for about five seconds, until your device restarts.
Amazon.co.uk Help: Can't Connect to Wi-Fi
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=202104870
Why does my fire stick not turn on?Restarting your device can resolve many issues-just disconnect the power cord (from the back of the device or from the power outlet), and then plug it back in. You can also use your remote to restart your device. Press and hold the Select and Play/Pause buttons at the same time, for about five seconds.Amazon.com Help: Basic Troubleshooting for Fire TVhttps://www.amazon.com/gp/help/customer/display.html?nodeId=202104850
if this does not help you.go to this link and see if its of any help to you.
fire stick is not connecting to internet Google Search
Nov 20, 2017 | Televison & Video
Can't connect amazon fire stick to tv, connected last night but won't connect today
Try unplugging the power from the Fire Stick, waiting a few seconds and plug it in again. Not a very technical answer but sometimes it works.
Jul 23, 2017 | Televison & Video
Netbook wont come on
Remove main battery and press power, next! remove one stick of ram and power on, still nothing! remove the second stick and replace the first one back and power up, if no headway! the DC jack in the laptop may have become intermittent, or motherboard issues, I suggest a professinal at this level.
Mar 12, 2012 | Acer Aspire One Netbook 8.9" Notebook
Tv powers off and on about 3 times then a little black box in back starts sparking. Its a 52 inch RCA. Thanks.
Be careful , can start a fire, keep unplugged,. you may have to get a repair man to look at it. Sounds like a short to me.
Aug 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont run for more then 10 sec
If you can do your own work, try some things if its dies you ether loseing fuel pres, injector control, or spark........ the fuel pres is easyest to ck, just stick a gauge between the pump and the rail, should be 42-43lbs, on the spark pull a coil stick and put an extra plug in it and fire up the bike be careful doing this is case of fuel leaks under tank, if the bike quits and you try to start it and you still got spark this may be ok, this is a bit more difficult, you have to ck the plug connections at the coil sticks, if you ck in a service manual each coil has two wires going to it one is going to be powered all the time, the other one is grounded by the ECM when the injector is supposed to fire, a node light will help in checking this, OR you can do what most of us do, take the bike to a good suz guy that knows what he's doing
Nov 10, 2008 | 2002 Honda ST 1100 Pan European (cbs-abs...
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
