SOURCE: My RCCD unit sometimes trips when I turn my main oven on
I'm assuming you are speaking of the line circuit breaker to the stove. If that is the case and there are ** other problems that you k**w of, it is possible that the breaker has gone bad....they do. Get the same brand and rating as you had originally installed. Cut your main feed and open the terminal panel and remove and replace the unit. Restart main feed and set breaker on. If you continue to have issues, check all wiring to your stove...a loose wire or corroded contact point may be a second issue.
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
SOURCE: beko dvc62 main fan oven stopped working, doesn,t
For all Free appliance repair videos visit our VIDEO
TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter.
To gain access to the NEFF element you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the element you will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the element
is open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine.
2, If your NEFF fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motor
is working you will
see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then
you need To replace the oven fan motor
is a little more
expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timer
into AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
SOURCE: oven tripped circuit breakers and now the main
No service manual available, but you can be assured that it is the element that is faulty.
No need to test it, just replace it.
SOURCE: Electrolux EOB 6632 oven trips
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
