Hi Michael Papaliam corroborates the position of the key that assigns the signal to the amplifiers, which is not in Bridge position or assigned to the monitors
Check and comment
Regards Franco Dosil
Hola Michael Papaliam corrobora la posicion de la llave que asigna la se?al a los amplificadores, que no se encuentre en posicion Puente o asignado a los monitores
Controla y comenta
Saludos Franco Dosil
http://downloads.music-group.com/software/behringer/PMP1280S_PMP880S_PMP860M/PMP-GROUP1_ENG_Rev_B.pdf
https://www.behringer.com/Categories/Behringer/Mixers/Powered/PMP1280S/p/P0568/Videos
I doubt that there is a problem with the unit. Usually people have problems with their cables or the speakon plugs themselves.
Unscrew the connector that is used on both ends and double-check their connections. Sometimes the screws that hold the heavy gauge wire in place, come loose. Also make sure that they are in the right places. Sometimes you have 4 connections. Make sure they are in +1 and -1 connections. Every once in a while you'll find a quirk unit that requires you to use +2 and -2 instead. Look at the back of the amp. It should tell you which numbers it uses. Make sure you check the same thing on the speaker end also. If you have a meter or continuity checker, use it to make sure it's wired right.
This is a professional piece of equipment. They don't go bad easily. Make sure you tighten those connections real good and that you pay close attention to the engraved numbers on the speakon connectors. (That is if they are quality connectors. The cheap ones may NOT tell you the numbering or the phase, ((+ or -)). Hint: The negative one is always closest to the outside of the plug. You'll have to study it to understand that. The screw terminals on the inside have 'walls' on both sides of it. Those are the + connections.
Also, check the switches on the front. You may have one of the switches in the wrong position or setting. Also if you're using phantom powered mics, you have to turn the phantom power on or else they will not work. Hope this helps.
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
SOURCE: Volvo 240 reverse lights don't work
Hi Sir
Checked the switch and plug? here's how :)
Yes it is the reverse light switch which is hooked up to your gearbox which needs to be replaced. Also it could be the plug going into this switch is a bit dirty or thorn (due to engine temperature and time wear) which in that case means that it needs to be fixed before replacing the switch.
Checking its actually the swtich so you don't buy it for nothing :)
Just to make sure that the circuitry is ok. Go to the gearbox (if it is front wheel drive transverse engine you wont need to go underneath) check where the gearbox and linkages are close to the revers there should be a switch n plug hooked up to it. Unplug it put in a piece of wire to short circuit both wires. Then turn the ignnition key on and if your circuitry is fine the lights should go on :) This means that its the switch for sure :) I hope that this helped your problem :)
CHEERS
SOURCE: No sound comming from the left side speakers in my 04 Envoy XUV.
first> road vibrations can cause cable connections to come loose so you can start by taking out your radio and making sure all of the questions in the back are connected as they should be.
Second> if this doesnt seem to work then the next step is to check the wires going to the speakers that arnt working (this will b quite a job, but if you can do it, it will save u quite a bit of money) .. checking the wires your checking for >bad connection to the speakers >cuts in the wire or if any part of the wire is touchin any other metal object
Was This Helpful ?
SOURCE: external speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
