Dear sir,
here i give you a video link how to transfer your photos and videos to pc.
https://www.youtube.com/watch?v=iTJ-4m8h4Ew
it will help you
Thanks,
SOURCE: PHOTOS ON INTERNAL MEMORY - HOW DO I TRANSFER THEM TO CARD SO THAT I CAN GET THEM PRINTED AT SHOP?
Hi KarenB,
Not sure if anyone ever got back to you on this but i just had the same problem then googled it and found this
Yes, the [BACKUP] feature will transfer files from the camera's internal memory to an xD-Picture Card™ flash memory card. It does not delete those files from the internal memory. To perform a backup, insert an xD-Picture Card flash memory card into the camera and then turn the camera on. Press the [MENU] button. Press the Right arrow button to select the Setup icon, and then press the [OK] button to enter the Setup menu. Use the Up or Down arrow to select [BACKUP], and then press [OK].
Wendy
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
SOURCE: How do I transfer images
Go into the menu and find "copy". It will give you the option to copy the internal memory to a card.
SOURCE: How can I transfer internal memory pictures to an
In the menu system of the camera, scroll until you find "copy" where you are given the option of copying the internal memory to a card in the camera.
SOURCE: I need to get photos
Easy...go into the menu and find "copy". There you will have the option to copy the internal memory contents to a memory card.
