Question about Sansui Televison & Video
Can you help me with Sansui tv SLED2490?
Moved from one room to another language wrong can't set tv to cable box channel
    Top Expert:
  • Sansui Master
  • 10,764 Answers
Go into audio settings on cable remote and change
Posted on Oct 08, 2019
Anonymous
SOURCE:
Anonymous
  • 790 Answers
SOURCE: 13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Posted on Oct 12, 2007
Anonymous
  • 34 Answers
SOURCE: cable box extension
just need some coaxail cable to the right lenth and two f connectors :-)
here is a good cable site i use on a regular basis.
http://www.satcure.co.uk/accs/page8.htm
hope this helps
can plz rate my solution
thanks nick
Posted on Dec 07, 2007
chrispurs1
chris pursloe
  • 372 Answers
SOURCE: setting up my freeview box- NO CHANNELS FOUND
Hi.
The cable & wireless system is not capable of picking up the digital freeview frequencies.
Idealy you need to put a new aerial on the roof,
If this is not possible try an indoor aerial that you to plug in to the mains electrical supply.
http://dysonmanuals.inc.io/
Chris..
Posted on Dec 12, 2007
JEfromCanada
  • 59 Answers
SOURCE: Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Posted on Jun 08, 2009
Anonymous
  • 55 Answers
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Posted on Nov 01, 2009
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
We have used this TV as a primary hooked directly to the cable box. Now we bought a larger Sony and want to put this one in another room. We unplugged the set from the cable box carried it to the other...
first, be sure the cable outlet is working. If so then you have to reprogram the tv by doing a channel search in "analog" since it's no longer connected via a "digital" box. Just go to the tv menu, search channels(analog) and start.
Jul 21, 2011 | Televison & Video
Tv plays on only chanel 3
if the tv is digital tv ,connect the antenna .in the menu select autoprogram. this scan channels.
Apr 26, 2010 | TruTech T2000D TV
One analog channel
hello have you got the aerial in the cable box and the lead from the cable box to the tv then you might have to click first time installation i hope this help's
regards
shaun
Feb 14, 2010 | Televison & Video
Cable box is working, TV has black screen and no
cable signal is weak. Tech. must check house wiring.
Jan 12, 2010 | Panasonic CT-32D12D 32" TV
This set was on a DVR cable box, but I moved it to another room, without a cable box. The problem is that I get no sound on two channels--the local ABC channel and TBS from Atlanta. I noticed that on the...
The SPA looks as if the box is just telling you that spanish audio is available. That would usually occur even if it isn't set to spanish, it is just showing it's available. Maybe try changing the audio channel? Ie. from TV to VCR back to TV etc. and make sure you don't set to SAP.
Lastly is ther an Atlanta Braves game on? Is it being simulcast on TBS and your local ABC channel? That may be the problem, it may be a problem with their telecast of the game. If this is the case, then call the cable company as it is a problem elsewhere.
Thanks!
EJ
Sep 28, 2009 | Panasonic Televison & Video
CHANNEL 47 AND UP ARE BLURRY AND NO VOICE
Try it again in the original room where the TV once was. If the channels from 47 and up are back to normal, its a cable signal issue that the cable company must resolve. Its possible that the installer may have driven a staple thru the coaxial cable or did not correctly attach the fittings.
michtech
Feb 17, 2009 | Televison & Video
Can't set up my new Nikkai 5.8GHz video sender.
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Nov 18, 2008 | Televison & Video
Channels not working
It was in the guide plus set up that I needed to redo. When I was originally using it I had it setup to be connected to cable box, but when we moved it into the other room when we got the new tv we recieved, there wasnt a cable box in there. I didnt know that I just need to reset the menus to delete it being connected to cable box and it worked. I hope this will help someone else if this problem occurs with their TV. Ron
Sep 16, 2008 | GE 27GT722 27" TV
Televison & Video Logo
41 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
