Question about Sansui Televison & Video
Sansui 32 led tv upside down picture - Sansui Televison & Video
    Top Expert:
  • Sansui Master
  • 10,679 Answers
Go into picture settings and change view
Posted on Oct 08, 2019
6ya staff
SOURCE:
silly girl
yoav kleinfeld
  • 513 Answers
SOURCE: sansui picture fault
Usualy a problem with the LCD screen itself, that takes replacing the whole screen to fix. Sorry. Could also be an internal connector that has gone bad. There are tiny transistors on most displays that control whole rows and columns. It sounds like one went bad, causing a dead, or constant on, column. Unless you are REALLY handy, it will probably need to go to a service center for repair, which could be very expensive. Try flexing your screen - wrap a non-fibrous cloth around your hand and squeeze the screen lightly all around the edge. If you find a point where squeezing the screen makes things better or worse, explore that point further. Squeeze just hard enough to make a white area go light grey or yellow. It's safe to squeeze gently with something fluffy when the computer is turned-on. Could be a cable problem - either the cable is not making a good connection at one end, or the cable itself may have been crushed and one of the lines in it broken. Replacing the cable is far cheaper than replacing the display. Good luck
Posted on May 17, 2006
Anonymous
  • 51 Answers
SOURCE: Insignia LCDTV32 Problem menu Upside down.
How can you see the menu if there's no picture? Need more information with this one.
Posted on Jan 02, 2009
Chi Chu
  • 8457 Answers
SOURCE: I have sound but no picture.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.It a long board in shape.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Posted on Mar 17, 2010
Anonymous
SOURCE: my sceptre television picture is upside down, can
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
Posted on Mar 21, 2010
specialistel
  • 8909 Answers
SOURCE: Picture quality is too bad in NEW sansui 32" LCD
As it is new, take it back for replacement. If you bought in online, have it replaced as it may have been damaged in transit.
Don't bother to try and repair it, it is not right.
Hope that helps.
Posted on Nov 27, 2010
MY 32 INCH SANSUI TV'S PICTURE IS UPSIDE DOWN 32SLED-HDR, how to fix such?
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the sites linked here. Pull up older posts.
http://homenol.blogspot.com/
http://electro-medical.blogspot.com//
Aug 07, 2018 | Sansui Televison & Video
Service code for 32inch sansui led tv sled hdr
Sansui model - LCD TV s 3281Yw-M I need sarvice mode code plz tell
Apr 29, 2018 | Sansui Televison & Video
My tv LED promac 32 inch the problem is iverted picture upside down. Pls help me or how can I enter service mode using universal remote control
Don't go into "Service Mode" you could make it worse. Possibly have a bad T-Con. Check E-Bay or shopjimmy.com for replacement.
Feb 02, 2018 | Televison & Video
My Sansui 32 lcd tv screen flipped upside down. How do I undo this screen flip?
Go into menu then service options click on normal for picture flip, and it will go back to being right
Nov 29, 2017 | Sansui Televison & Video
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
How do I fix an upside down SLED-32HDR TV screen
How to invert LG LED TV pictures upside down by 180 degrees
But that is for an LG TV. The same phenomena occurs regarding motherboards in some other brands. Your brand is a Sunsui.
If used with a computer:
if connected to a computer, cntrl alt + up would flip it back to normal(for some computers).. if that shortcut doesn't work you can go into control panel and flip the orientation. Or right click on an open section and select screen resolution (Win 7) The resolution will say something like Landscaped Flipped.
Here is a number to Sansui support: http://www.sansuiproducts.com/support/support.html
Aug 22, 2017 | Televison & Video
Hi where could I get a sansui flatview 32" remote?
Obviously you could get one from sansui or better yet try ebay they probably will have one it may be a few weeks until one or more show up. Some links to try:
Sansui TV Remote Controls
Sansui Remote eBay
NEW Orion Sansui JVC LED TV Remote Control 076E0TT011 Supplied with models... Replacement Remote for SANSUI HDLCD1909 HDLCD19WB HDLCD1909A
Feb 12, 2015 | Sansui Televison & Video
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Sep 10, 2007 | Sansui TVM1916 19" TV
Televison & Video Logo
29 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
