Radio Communications Logo
e
eaadrano Posted on Oct 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to disable frequency name in Motorola CP1660
John L radiodude365
Level 3:
Master:
  • Motorola Master 570 Answers
  • Posted on Oct 04, 2019
John L radiodude365
Motorola Master
Level 3:
Master:
Answers
570
Questions
0
Helped
209623
Points
1236
It requires the radio programming program. You must take it to a dealer. It will cost a bit to be reprogrammed, call in advance.
How to unlock motorola cp1660 radio?
Long press P3 and check key sign will be goes OFF, now your keypad is unlock.
How to reset motorola CP1660 to factory default
Have you removed the battery and left it out overnight ??
Channel error on motorola cp1660
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Can the motorola t6500 talk with other two ways?
It can talk with any radio that operates on the same frequency as it. These are what are commonly reffered to as FRS (family radio service) radios. The name brand does not matter, but the frequency does.
Can i change the frequency on this router it is interfearing with my security system
http://broadband.motorola.com/consumers/products/sbg900/downloads/sbg900_user_guide.pdf is a pdf of your manual. On page 71 it shows a menu that allows you to select a channel.
"Channel" is another name for frequency. It probably defaults to channel 1, try setting it to channel 11. Or channel 6.
Motarola VT2542 Wireless Router: If you disable the wireless on the router's software does that stop the router from broadcasting rf frequency? I would like to use the router as a wired router without rf...
Hi! It's ok to disable the wireless broadcast of the router however, it wont stop the router from broadcasting the wireless frequency. It will only hide itself from the people who are trying to connect to a free signal that are available.
2answers
Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
