Question about Exercise & Fitness
E06 panel error on Ancheer treadmill - Exercise & Fitness
3 Suggested Answers
Anonymous
SOURCE:
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: I have got E06 error in Lifespan Treadmill.
I have read that the speed sensor near the front flying wheel connected the front roller, sometimes get malfunction. I have just tapped it gently with a screwdriver and this seems to have done the trick. Hope this will help somebody with a similar situation.
Else
Call Vision Fitness Customer Service, they'll help you reset the treadmill by using the console. This will help clear the problem. I've been told that this error occurs when the incline controls are not used often. I've cleared the error using their instructions but after several months it does reoccur. And no I don't use the incline option often so that might explain it
Posted on Oct 04, 2012
gopakumarg43
  • 76237 Answers
SOURCE: It is my treadmill tx4000 why do I get error E06
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Posted on Jun 05, 2014
How to fix error code 6 on a roger black treadmill?
1)E00 Safety Key not in the position Re-locate the safety key in the correct position.
2)E01 No signal to Controller from the console
A: Check the Main Controller Wire
B: Replace the PCB Board
3)E02 Motor communication error
A: Check the wire from motor to controller
B: IGBT breakdown, Replace the controller
C: Check the power voltage if 50% lower than rated voltage
D: replace the motor wire or change motor
4)E04 Incline Motor communication error
A: Check the wire from incline motor to controller
B: Replace the incline motor
C: Replace the controller
5)E05 Over current protector
A: Overloading or over resistance,
restart the treadmill
B: Transmission parts seized up, check the parts
C: Replace controller
D: Motor breakdown, change the motor
6)E06 Motor Open Circuit.Connect the Motor link
7)E08 IC Driver Error. Replace the IC driver or change the
IC driver
8)E09 Folding up protect.
A: Do not fold up the running deck when treadmill in is running
B: If the running deck in laying position and show E09, you need to change the controller
9)E10 Motor instantaneous current abnormal
A: Adjust the torsion potentiometer of the Controller to lower
B: Motor Breakdown, change the motor
10)E11 Overvoltage protector Voltage over 270v (for 220v) or 150v (for110v) -- turn off the treadmill and check the power source
11)E13 No signal to console from the controller
B: Change the controller
12)E14 Lower voltage protector Voltage lower than 160v (220v) or 70v (110v) -- turn off the treadmill and check the power source
Oct 26, 2017 | Exercise & Fitness
Manual for ancheer 20" folding bike
Ancheer support page: SUPPORT
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Aug 23, 2017 | Cycling
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Sir i hav feced a e06 error in mp287 pixma plz solve the problem
Try this solution I found on a German site. Other sites I found did not even mention E06 as possible. Site is linked below, you can use GoogleTranslate to convert to your own language. Good luck!
Error E06 Canon MP287
The characteristics or signs:
  • Currently in turn on the printer does not print the worksheets.
  • ALARM indicator light lit In follow with lights flashing orange ink information.
  • LED indicators display appears on E06
How to Reset Error E06:
  • Press and hold the stop / reset until the standby light green and then release.
  • If the indicator light still flashing again, repeat again by pressing the stop / reset.
  • Finished
Dunia Printer
Jul 06, 2015 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
I lost my manual for Snappy Chef. I do not know if E06 appear what does it mean.
LOOK UP ON LINE TYPE IN E06 OWNERS MANUAL OR E06 PARTS MANUAL MAYBE ONE OF THOSE WILL SHOW YOU WHAT IT MEANS THE E USUALY STANDS FOR ERROR. THE 6 COULD MEAN THE OVEN OR BROILER OR A CENCER.
Feb 02, 2015 | Ovens
It is my treadmill tx4000 why do I get error E06 every it I start it up
Jun 05, 2014 | Exercise & Fitness
Pz 50hv2
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Error code details to many brand TVs are given.
Jan 08, 2014 | Televison & Video
Panel shows code error e06
tengo un error E06 tengo 2 meses que compre el equipo espero puedan ayudarme mi correo es nicolas82191@hotmail.com
Jan 03, 2013 | Lime Pro Equipment D7.3 Treadmill
Else
Oct 01, 2012 | Lifespan Exercise & Fitness
E06 error--how do you get rid of flashing this error and what causes it in the first place. Thanks
Finally resolved this on our own tub. We had C01 and E06 error alternating. After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
Feb 10, 2010 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Exercise & Fitness Logo
107 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
