Question about JVC Televison & Video
JVC model:LT-50EM76 flatscreen, Right side of screen is very dim. Which board can that be? The back lights appear to be working fine.
    Top Expert:
  • JVC Master
  • 76,171 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Oct 06, 2019
6ya staff
SOURCE:
Anonymous
  • 59 Answers
SOURCE: dell inspiron 1520 screen dim on left side
make sure there are no speakers at the side of the monitor as the may not be sheilded. then unplug monitor from the mains and plug back in to reset. or in the monitor menu select degauze .
Posted on Apr 05, 2009
ourhowse
Dar
  • 2007 Answers
SOURCE: jeep - right turnsignal won't flash
Probably a bad ground on your front right signal, or a bad bulb. Try switching the right with the left, and see if the problem stays in the same place, or goes with the bulb.
Posted on May 18, 2009
vinhson65
  • 257 Answers
SOURCE: I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Posted on Aug 13, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: JVC Everio camcorder Model No. GZ-MS230AU Problem
There are two possibilities for said problem, either ccd imager chip is bad or aperture is not open located in lens mechanism.
Turn On camcorder while looking inside front lens, if you see aperture opens like an eye inside lens mechanism then ccd imager chip got bad and need to replaced and if aperture does not open then aperture needs to be checked, in either case a professional is needed to fix the problem because it is not user level repair and camcorder will take apart in detail.
Hope these info will help you.
Thanks.
Posted on Nov 14, 2010
e-Guru
e-Guru
  • 3917 Answers
SOURCE: There was a power outage. When the power can back
You refrigerator has gone to a safe mode. You have to reset the control panel to get back to the normal mode .For that you have to press the top left the Energy Saver and top right Alarm buttons together for about 10 seconds--it will beep and reset the panel.
Hope it will help you.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 24, 2011
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Jan 11, 2016 | JVC Televison & Video
I have a LT-42E478 and the left side of the screen is dull, what to do?
In some models of LCD TVS; the backlight inverter will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, it can't be replaced. In this case; a panel replacement is the only repair.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 08, 2015 | JVC LT-42E478 42 in. LCD Television
Left hand side of TV screen is blacked out on my JCV TV model LD-42DR1BJ
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 19, 2014 | Televison & Video
JVC tv sound but no picture
It could be a main board, but it could be a backlight problem. To verify this, turn on the set, dim the lights in the room, shine a bright flashlight on the screen. If you see a faint picture, you have a backlight problem.
Jan 09, 2013 | JVC LT-52X579 52 in. LCD TV
Black screen in jvc lt 42e478
If you can see a dim image when you look at the screen at a sharp angle then you most likely have a faulty inverter board or faulty CCFL lamp/s.
Most likely faulty inverter board which supplies high voltage to the CCFL lamp/s.
Jan 16, 2012 | JVC LT-42E478 42 in. LCD Television
JVC LT-37X688 37 in. LCD TV. When powered on there is a brief flash of light on the screen and then the screen is black and stays black. Audio is fine and I can still use all of the remote controlled...
No lamp on LCD tv.The LCD backlight inverter board it dead,that board needed replaced to get picture back.Tries Shopjimmy.com,Ebay.com to buy the LCD backlight inverter board.It usally a long board.The refurbish LCD backlight inverter board about $100-$120.
Feb 14, 2010 | JVC LT-37X688 37 in. LCD HDTV
Several smokey lines cross the screen
I probably had the same problem. The cause is a bad main board ($276+-), digital board ($225+-) or analog ($102+-) board. Labor should be about $130. The actual lcd should be fine.
JVC will only issue a recall if 1500+ complaints on a model.
Mar 20, 2009 | JVC LT-26WX84 26 in. LCD HDTV
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Mar 17, 2009 | JVC LT-32P679 32 in. LCD TV
Power problem with JVC LT-32x576
there is a firmware update for this model download from jvc website onto a thumb drive and plug it into the side plug.
Mar 10, 2009 | JVC LT-32X576 32 in. LCD Television
Pink screen
Dear LT user,
Your LT has one of the following 2 problems: Your LCD cable might be faulty OR your inverter board is malfunctioning.
The LCD cable is responsible for transfering "color information" or "screen data" from the motherboard to your screen. If this cable is faulty or malfunctions, it can result in a lot of appearances - in your case a pink screen.
The Inverter board is repsonsible for the "light" on your screen. If the inverter board is faulty or does not function properly, you might experience this issue.
If your LT is still under waranty, you can give it in @ the nearst HP Warany centre for repairs. If not ; HP parts are very expensive.
What you can also do, you could install an external monitor (LCD flatscreen) to your LT. Because the Flatscreen cable connects to your VGA port at the back of your LT, using an 15 pin blue connector , it connects directly to the Mainboard so it does not run over the LCD cable and thus will be a unit on its own.
Kind Regards,
Stef
Apr 16, 2008 | Compaq Evo N610C Notebook
Televison & Video Logo
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
