You have to go to the menu and set it to use the EXTERNAL memory card instead of the internal memory. Make sure that the external memory isn't too big for the camera's capability. Some units can't handle more than a 64GB or 128GB memory. Anything bigger and it won't accept that you eve put anything in there.
Camera LCD: "Internal memory is full" ... If you insert a card and still get the "Internal memory full" error, it means the Storage Location setting is set to Internal Memory. Press the Menu button, then find the Storage Location choice. (It may be under the Setup
Probably camera has it's own memory & it is full.
Look under settings for option to switch to SIM card for picture storage.
SOURCE: Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Hi.
Enter main menu, scroll down to "Setup Menu" and then navigate to "FORMAT". Simply format your internal or external memory, and thats it.
SOURCE: camera says "internal memory full"
Goto srtting > storage > set primary storage as memory card.
SOURCE: Kodak EasyShare 330: Internal camera memory is
Try to transfer pictures from the internal memory of your KODAK Digital Camera to a memory card?
Follow these steps:
SOURCE: Brand new camera, unable to take any pictures.
If you used the internal memory even once, the memory card will not work until you get rid of whatever is in the internal memory. Do this...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
