Question about Westinghouse Televison & Video
Contour 2 remote linked to TV but won't change the Input. Then I was holding the remote, leaned on it unintentionally and the input changed but I don't know what I pressed! Help!
So I need to know what combination of buttons will change the input on Westinghouse TV with the Contour remote. I have no TV remote.
    Top Expert:
  • Westinghouse Master
  • 76,204 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Posted on Oct 06, 2019
6ya staff
SOURCE:
Anonymous
  • 30 Answers
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Posted on Oct 15, 2008
Anonymous
SOURCE: rca rcu600d universal remote
go screw your mom
Posted on Jan 06, 2009
Anonymous
  • 34 Answers
SOURCE: no remote, no input button on the tv. how do i
if there is no button on tv, the best bet is buying a universal remote and programming it for that tv
Posted on Oct 21, 2009
Chi Chu
  • 8457 Answers
SOURCE: I have a Toshiba 24af42 with no remote.
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
Posted on Oct 22, 2009
Anonymous
SOURCE: I lost my remote and
How to get the input on the tv without the remote
Posted on Nov 12, 2009
Remote frequency for my cable receiver seems to be the same as the remote frequency for my TV
Hi Thor!
You have to select "Cable" on the universal remote on the cable to change the channels on the cable box.
And press "TV" on that remote to change or access TV Functions.
Or use only the TV remote only to change Inputs on the TV.
Good Luck,
JP
Oct 25, 2015 | Televison & Video
Www roku com link
This sounds like a basic setup, so correct me if I made any wrong assumptions.
You have 2 "output" devices: a Roku and a cable box. Both have HDMI outputs.
You have 1 "input" device (your TV) that has 2 HDMI inputs available.
So, you need one HDMI cable to connect your cable box to your TV. Remember what HDMI port it's connected to - the back of your TV probably says "HDMI 1" and "HDMI 2" or similar. That's the "input name" of your TV.
Connect your Roku to your TV with another HDMI cable.
Now turn on your TV and use the remote to change between the inputs. Most remotes have a button that says INPUT or SOURCE (or sometimes a dumb little icon with no writing). If you press that it should change inputs. Usually, each time you push the button will cycle to the next input, so sometimes you have to hit it a bunch of times until the on screen menu shows the input you want. Most TVs will automatically switch to the selected input after a few seconds, so you don't have to push any buttons on the remote to tell the TV to change inputs.
If "at the same time", you meant actually watching both Roku movies and your cable at the same time, you are talking about a TV feature usually called "picture in picture". That should be possible, but will depend very much on your TV. I'd suggest checking your TV manual, or calling the company's 1-800 number and asking them to talk you through it.
Jan 07, 2014 | Computers & Internet
I bought a Sylvania TV, model 6420FF at a second hand store with no remote. I bought a universal remote and it still won't recognize I have the xbox or Wii on. What to do?
Setup codes to check with Sylvania brand TVs are: 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
For more codes to different other brands of remote controls, and setup proceedings, check this link.
Feb 05, 2013 | Televison & Video
My rca remote won't go to input or do anything
1) change the batteries by new ones
2) open the remote control clean the keypads from oxide, bad contacts,corrosion, dirty, and fix it.
3) try again, if doesnot work, you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | RCA Televison & Video
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
My remote wont let me change the input on my tv i have a viore tv, dish network, and a sont dvd player. Every time i try to change the input my remote only controls the chnnel its on. How do i change the...
Hi there! this is Kimberly Escobar with Dish Network Customer support, I just ran across your post and would like to help you out by providing you the information that can help get this issue resolved. To program the remote to your Viore T.V you can try code 738. What you would need to do is press and hold the clear T.V button located on the upper left hand corner of your remote (you will see all the other top buttons light up) then you will let go of the T.V button and enter the number 738 followed by the pound (#) key, notice you will see the clear T.V button flash 3 times. After this you can try the volume function and turning on and off your T.V. If it works you can try changing inputs on the T.V by pressing the T.V/Video button or Input button on the remote. Unfortunately we can't promise our remote will control all the functions on your T.V we also have this link available that you can as well find very helpful http://www.dishnetwork.com/SupportSection/remote-setup and you are more than welcome to also contact us directly. Thank you hope this helps.
Jan 23, 2011 | DISH Network IR Remote Control
I have lost the orignal remote for my tv and have a universal remote. I get the tv/video button to work. is there some way to change it with out using the remote?
Unfortunately, the Input button (to change the source from INPUT 1, INPUT 2,
INPUT 3, INPUT 4, Front Input, HDMI/DVI, and last-active channel) is only on the remote. If your universal remote was built 6 months after the TV was released, try a different code for RCA/Thomson TVs (assuming the remote has an input or source key). Thomson built the TV.
If your universal remote doesn't have an input key, you probably need a higher end remote (one with that key or one that can be programmed from a computer). Alternatively, you can get an exact replacement remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HD52W58&uuid=12927154203570 .
I hope this helps.
Dec 18, 2010 | RCA HD52W58 52" TV
Can I change input mode manually?
Try channel button to 1-2-3--99-98-1-2-3 up & down it should come between 0 & 1
Jan 21, 2010 | Sylvania SRT2232S 32" TV
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not...
Oct 22, 2009 | Toshiba 24AF42 24" TV
I set the INPUT to INPUT 2 but when I change channels it will not stay there. How do I lock it into place? Also, how do I set the clock on the TV? I used the menu, went to D.S.T and SET CLOCK, but at that...
your not saposed to use your tv remote to change chanels if you put it on input 2, im assuming you have a cable box, that is plugged into input 2, and if you are using the cable remote, after you put the tv on input 2, make sure you push the little cable buttom at the top of the remote befor you change the chanel
Jan 07, 2009 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
