I had this same problem with one of my refrigerators. Most refrigerators that do not have a screw you can access will clip on to the door. Be careful because this may not be one you can do, but you should at least try. All I did was pull up firmly on the handle and it shifted up and the mounting hardware for the handle had 2 screws in it. I tightened the screws back down and clipped the handle back on. I am not an appliance pro, I am only speaking thru my own experience. Please be careful when you do this. If you feel it is too risky, then wait for a response from a pro.
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
You have an air leak. Usually right where you frost build up is, however since hot air rises, sometimes this leak can be anywhere. Make sure your door closes tightly and your gaskets are clean and making good contact. You may have to adjust the gasket, adjust the door, or replace the door gasket. If there is ice on the floor of the freezer, you have a plugged drain line. In very rare instances we have found, where the freon lines enter the freezer, in the back or under the freezer, missing or fallen refrigeration putty that seals around the lines. Good Luck, Appliance Specialists
This problem can mean outside air is getting in. Look at your door seal, is it cut or crimped or out of its sattle. Another pos. problem is defrost. During the defrost cycle heators turn on and cause steam inside to rise up and collect at the roof, then refreeze, check the back panel for a good tight fit inside, is it bent or warped? That will let out the steam vapor that should stay right at the evap coil.
Download the PDF look at picture confirm this is your refrigerator and and read the Q&A on second link This will help you solve the problem, Let me know, Thanks, Sea Breeze
