Microwave Ovens Logo
C. McIvor Posted on Oct 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size glass turntable will for a HB microwave, model #P70B20APB8?
Poppa Maddo
Level 2:
Sergeant:
  • Expert 372 Answers
  • Posted on Oct 18, 2019
Poppa Maddo
Expert
Level 2:
Sergeant:
Answers
372
Questions
0
Helped
118760
Points
687
Platters come in many sizes and with many different means of being rotated using either "Drive spiders" or "Drive Spigots". Try the manufacturer first or look up on Google or Ebay or Gumtree to see if someone local to you has the same oven up for sale.
5 Related Answers
donald morrison
  • Posted on Oct 10, 2006
SOURCE: Emerson microwave Glass turntable replacement
When I used to repair microwaves I would pick up along the roadside for trash pickup. The Glass turntables would useally be saved by the owner. After they would find they have no use for it they would give it to the Salvation Army or some other thrift store. I have replaced many trays this way for around two to three dollars. You can also buy them from internet electronic stores, but they may sell for as high as 29.00. If you find one at the thrift store check the turning pattern on the bottom of the dish to see if it matches your microwave. There are ony a few differant sizes and types being used. Hope this helps.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 18, 2007
SOURCE: broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 04, 2008
SOURCE: Melted turntable support
Yes, that's part # WB06X10138 (coupler) and you can get it here.
You will need to remove the bottom cover of the microwave and remove the turntable motor to get the new coupler in.
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • 706 Answers
  • Posted on Sep 21, 2008
SOURCE: microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Anonymous
  • Posted on Nov 26, 2008
SOURCE: Emerson Microwave
http://microwaveglasstrays.com/shop/emerson-microwave-glass-turntable-plate-tray-as23p43-p-249.html THIS PLACE HAS REPLACEMENT TURNTABLES WITH LISTS OF MODEL NUMBERS SO YOU KNOW YOU GET THE RIGHT ONE.
What size turntable plate is needed for ge microwave jes738wj02
The GE JES738WJ02 uses the WB49X10134 turntable tray. According to Amazon, the tray measures ~9 5/8" in diameter. Sears Parts Direct has the parts diagram here: https://www.searspartsdirect.com/model-number/jes738wj02/0432/0123245.html . Amazon describes the tray on the part site: https://www.amazon.com/GE-Microwave-Glass-Turntable-WB49X10134/dp/B00DZPVBVY .
I hope this helps.
Part number for turntable glass tray
Only two Sizes of Turntable Glass Tray , Each manufactuer has his own number, but any Microwave repairer / supplier can help you. Try Yellow pages.
1helpful
The glass turntable broke. Where can I find a replacement?
Go to www.ebay.com Type: make and model of microwave, and refine search to glass plate.
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Cookworks microwave oven with grill and convection model cmx60 - I need new glass turntable unable to sourced bought from Argus about three years ago please help.
Microwave turntables are in several sizes
Here are a couple of sources for them. What you have to take note of is the wheel tray also. You may get the right size turntable and not fit the wheel tray. Manufacturer is not as important as the size and tray fitting.
This one seems a bit small at 10 inches but as your microwave is only 800 Watts it may just be the correct one :
http://www.argosspares.co.uk/cgi-bin/product.pl?PID=1162473&brand=Cookworks&model=&part=
You may want to call Argospares 0844 55 70 320
or make an inquiry here: http://www.argosspares.co.uk/cgi-bin/pne.pl?brand=Cookworks
Thanks for choosing FixYa.
Kelly
Need replacement glass turntable for inside a Galanz microwave, serial number HT0704046995
If you know the size (diameter) of the turntable, it would be much easier just to find another one of the same size rather than finding the exact part as the number matches nothing.
you may find a replacement one from the link below, just look for one with the same dimensions and it should work
http://microwaveglasstrays.com/shop/microwave-glass-trays-c-21.html
let me know if you need anything else
my best to you
2answers
Emerson Microwave
Shalene Naig
[email protected]
2873 410 Avenue
Graettinger, IA 51342
7128593720
I'd love to buy your glass turntable/
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
