Question about Polo Watches
Can't set day or date on US8532
US Polo assc. watch has 4 buttons
    Master:
  • 579 Answers
Usually you press and hold mode button until time or date start blinking. Then use another button to change a value and reset button to advance to another position, for example day, month, year, ....
Posted on Oct 07, 2019
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: setting the time, day, date, ona Festina 16059/4
Alhamdulillah, the problem solved (at last) tks to IRONMAN (https://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Posted on Jul 05, 2009
Anonymous
  • 3 Answers
SOURCE: adjusting Date and day on a Festina 3 dial watch
Anonymous
SOURCE: I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
Posted on Jul 08, 2009
malambert313
SOURCE: Setting Time on Aqualite 4 button 30M watch
hold lower left button for 3seconds, use upper right to select hour, minute. lower right to change. lower left to complete change.
Posted on Jul 21, 2010
camont1
  • 3 Answers
SOURCE: configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Posted on Jan 07, 2011
How do I set the time on an accutime digital watch FZN3694?
For da only person dat left a comment I figured it out ... The bottom button gives u access to change the time ... Take something hard n pointy and push hard in da middle of da bottom button you have to force the butto in ... And take it from there ....
My email: Steadyray8@gmail.com
Feb 05, 2015 | U.S. Polo Association Mens Calendar...
How can I set the date on my watch? I could set time and alarm but I couldn't set the date .
Hi ajcruz_h,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Mar 04, 2011 | Timex 1440 Nylon watch
How to set time on a 1440 timex watch
Hi tsgoode99,
Timex Digital Watch
Hope it helps.
Dec 25, 2010 | Timex 1440 Nylon watch
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Dec 05, 2010 | Armitron 40/8125BLK Digital Sport Watch
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
I cant set the right date on my timex 1440 sports watch
Hi travislietha,
To set the right date on your timex, please follow the instructions below.
Hope it helps.
Jun 28, 2010 | Timex 1440 Nylon watch
1440 date change
Hi jhnmeserole,
Timex Digital Watch
Hope it helps.
Nov 05, 2009 | Timex 1440 Nylon watch
We don't know how to set the 1440 sports watch
Hi katbil1,
Timex Digital Watch
Hope it helps.
Oct 24, 2009 | Timex 1440 Nylon watch
I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
Hi 1234910,
Hope it helps.
Jul 16, 2009 | Timex 1440 Nylon watch
Two cheap chronograph watches that won't set date and month
This is a cheap watch, but there are lots of online sites that provides fashionable and good watches.
You can your fashion design watches here Top Seller of Week 10 Discounted Watches 24 7
Dec 16, 2007 | Watches
Watches Logo
Top Polo Watches Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Bill Boyd
Are you a Polo Watch Expert? Answer questions, earn points and help others
