Question about Samsung Televison & Video
Samsung tv bought in US says input 110V. Powerboard BN4400554B seems to indicate 110-240V 50-60Hz. Can I plug into SA outlet without converter?
6ya staff
SOURCE:
Anonymous
SOURCE: Plugged into 220V outlet by mistake! Help!
I don't know for sure, but I suspect that if you open it up, there should be a fuse near the power supply portion of the unit. It may have taken the hit for you and can perhaps be replaced easily. (As a disclaimer... be sure the unit is not plugged in when you open the case! And only replace the fuse with another of equal rating.) If it's not a fuse, then you probably smoked the primary winding of the transformer. If it got past that, you may have popped the rectifier and/or capacitor(s) in the power supply.
Posted on Jun 04, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Power cable problem for SHARP AQUOS TV 42 inch
The voltage rating of the cable is not a problem. For all home appliances, including TV sets, the voltage rating of the power cable is supposed to be up in the 600 Volt to 1000 Volt range depending on the particular manufacture of the cable. This is not an issue. I have never seen a home appliance that could handle more than 240 VAC.
As for the Amperage rating of cable, it is more than adequate for the appliance that the cable is sold for. The 220 Volt appliances use about 1/2 the amperage that their equivelent 120 Volt appliances use. This is because the wattage for the power consumption is normaly constant.
The power cable is not a factor here. If the power supply in the TV can take the 220 VAC, and the 50 Hz power line frequency then there are no problems from that point.
Jerry G.
Posted on May 21, 2008
Anonymous
  • 6 Answers
SOURCE: plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Posted on Mar 09, 2009
Anonymous
SOURCE: Samsung WA71N2, plugged to 220V should be 110V only
chang the board! servise center will charge probably 400sr
Posted on Feb 03, 2010
Jerry Umali
  • 979 Answers
SOURCE: 110v lcd tv was plugged to 22ov outlet
Hello nik286, hi, check first the label at the back of the TV, look for a voltage input something like a 90V-240V, if you see this, its an autovolt system, this type of power supply input is standard nowadays. Assuming your asking what would be damage, this could be anything from the fuse, thermal resistor, rectifier diodes, and the regulator IC of the power supply board.
Posted on Apr 12, 2010
I received a ryobi 36v battery charger as a present. It was brought in America and has a American plug. Can I use this charger in Australia
Australia has a 230v supply, and the US 110v. The power supply for your charger will indicate what input voltage it can handle. PCs, for example, typically have power supplies that can use anything between 100v and 240v, which means you can take your laptop from country to country without worrying. My Ryobi charger on the other hand says 240v input, so it doesn't have this flexibility - usually it wouldn't need to. If yours says 110v then you'll need a converter for it to function properly in Australia.
Jan 12, 2018 | Ryobi Drills
I have a panasonic home theatre system Model No SA-HT690 and want to bypass the DVD player and hook it up directly to my new Samsung TV. I want to be able use the surround sound when watching TV and u
you want to instead pass the audio from the blueray
either direct to the sa-hr690 via one of its aux inputs
or via the TV
via the TV makes sense
so find an audio out from the tv
some only have headphones
some a pair of phono plugs
so youll prob need phono to phono cables
and then your good too go
Dec 07, 2014 | Samsung Audio Players & Recorders
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
When unit is plugged into a power outlet, the power indicator lights up for about two or three seconds, then a click is heard and the indicator goes off. The indicator immediatly light up again then after...
The problem is the television is not getting the correct amount of power, so a breaker inside the tv is flipping, thats the click you hear, the problem could be within the TV itself or the outlet it is plugged into, try plugging the TV into another outlet and if the problem persists you will have to call either the store you bought it from or the manufacturer.
Mar 01, 2011 | Samsung LNT3242H Television
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Apr 12, 2010 | Sansui 19 in. LCD TV
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Jerry G.
May 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
