Question about JVC Televison & Video
Im trying to get a jvc av-27730 out of lock mode
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 375 Answers
SOURCE: Where to find the Diagrams JVC AV-27730 27"
try servicemanuals.net
Posted on Mar 28, 2008
jmccawley74
SOURCE: JVC AV-27730: horizontal bright line across screen in the
if you havent fixed your problem yet, i had the same problem twice. It turned out to be the vertical hold. i have had the tv for a long time and had three problems. like i said twice the vertical hold and now i have no picture with a blinking light. i may give up on it and get rid of it
Posted on Nov 14, 2010
gopakumarg43
  • 76204 Answers
SOURCE: i have no picture on my JVC AV-27730 tv. Where is
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Posted on Mar 06, 2011
Prasanna
  • 879 Answers
SOURCE: how do you set up a remote on a jvc av-27730 tv
Check this site for more details. "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English.
You can get all details here. Pull up older posts. Codes and setup proceedings are described in detail.
Posted on Jun 18, 2012
How do you set up a remote on a jvc av-27730 tv
Jun 17, 2012 | JVC AV-27730 27" TV
Tip
Here is the manual for the av 27730
http://tv.manualsonline.com/manuals/mfg/jvc/jvc_av_27330_av27330.html?idRes=720867
on Mar 28, 2014 | JVC AV-27730 27" TV
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Hello
Mar 06, 2011 | JVC AV-27730 27" TV
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
JVC PROJECTOR TV 61INCH
try to checked the memory program I.C. located near the controler I.C. or it maybe put you on timer mode, try to go menu and checked the settings
Jul 30, 2009 | JVC AV-27020 TV
Locked!
try entering your menu setup and turning off the text and cc modes,look on your remte for the function also.
Apr 13, 2008 | JVC AV-27230 27" TV
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Abnormal crackling sound from speakers
check the Audio if ic or something gone bad around it. good luck
Apr 28, 2007 | JVC AV-27730 27" TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
63 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
