JBL Northridge E80 (Single) Main / Stereo Speaker Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jbl e80 no sound coming from tweeter
There is no sound coming from one of the tweeters in my jbl e80s. I unscrewed it and found that the two wires have not come unconnected from the tweeter. Anything I can do?
t support
Level 2:
Novelist:
  • Expert 169 Answers
  • Posted on Sep 21, 2009
t support
Expert
Level 2:
Novelist:
Answers
169
Questions
Helped
55172
Points
280
Sound like the tweeter is blown, take to local jbl agent for service.
Have 2 jbl 615 get good base and sub but neither tweeter playing
You will need to determine if it's the amplifiers or the tweeter themselves that are not working. If you open up the cabinets and check each tweeter with an ohm meter for continuity it will show if the tweeters are working, in which case the amp is the problem. if the meter shows that the tweeters are blown, you should still hook up another tweeter or speaker to the horn amp to see if it's blown and therefor took out the tweeters.
If any of this sounds complicated, you'd be best off taking the cabinets to the repair shop.
2helpful
2answers
The tweeters are not working
The crossover caps may have failed, or the tweeters themselves burned out. Using a small 1.5 volt cell touched across the tweeter leads should produce a sound. If not- they are burned out.
The tweeter and upper mid-range speaker quit working in one of my JBL s412p speakers. All wires are connected. Would this be a cross-over assembly problem? If so, where can I purchase a replacement?
Remove the speaker wire from your amplifier. Using a 1.5v battery place the wire on both ends of the battery. Observe if you can hear a cracking sound on the tweeter and the mid-range. If there is no sound., your speaker is busted and needs to be rewind or replaced.
I installed a brand new tweeter in my JBL EON 15 G2 & the new tweeter blew. What else could be the problem?
These are "powered" speakers and any little bit
of distortion can be amplified enough to "blow" it!
Also the amp could be "shorted"! Have your JBL
dealer test it!!!
With the VHF on I can here the signal coming from the transponder, The orange indicator light soon changes to green pulsing gently. The E80 display unit displays ''No Data Source'' yet when the...
I would recommend upgrading the E80 and the DSM to the newest software levels:
E80 - 5.52
DSM - 4.12.
You can download the software off raymarine.com and load them onto different compact flash cards. Both softwares are upgraded through the E80 display.
4helpful
3answers
Auto speaker wire diagram
FYI - I just took our 2004 Sequoia in because of speaker rattle coming from the front door speakers. Before I could tell them the problem, they guessed what it was. They see loads of Sequoias and Tundras with JBL systems due to the front door 8in speaker, basically, coming apart. His suggestion was to replace only the bottom 8in speaker, because the top tweeters usually are in good working condition. There is a minimal failure rate on the tweeters.
Eon 15-g2 upper part of my jbl is getting hot
The tweeter is not the problem. The Eons use the vents below the tweeter to cool the amp and woofer. Sounds to me like you have a power supply problem in the amp, possibly a bad capacitor or diode. You have to check the amp for proper operation.
Sound cuts out after a few minutes of operation
I blew the tweeter in my jbl stadium floor standing speaker. I would like to know how to remove the cover in order to replace the tweeter. I already purchased the tweeter and it is on the way. I don't want to damage anything in my attempt to remove it.
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
