Televison & Video Logo
John Adams Posted on Oct 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio E601I-a3. Black screen with white flickering near the bottom. Does not power off with the power button. I am unsure of the cause. Does this point to a particular part?
Franco Dosil
Level 3:
Top Expert:
  • Vizio Master 10,542 Answers
  • Posted on Oct 14, 2019
Franco Dosil
Vizio Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377800
Points
178965
Hi John Adams, as you comment, it would seem a failure on the Main Board
Hola John Adams, por lo que comentas, pareceria una falla en la placa Principal
Testimonial: "@Franco - I did some testing on the power supply board and found dead or irregular voltages. Going to try that first. Thanks for the input, I'll let you know."
  • Franco Dosil Oct 14, 2019
    All right, John Adams, thanks for answering
    I await the news
    Regards
3 Related Answers
sonicboomele
sonic boom electronics
  • 1557 Answers
  • Posted on Jul 05, 2016
SOURCE: Need to know replacement parts for vizio E601i-A3. It took a power surge from Lightening strike. Turns on but after 30 sec, squeals.
The squeal is likely to be a leaking capacitor find the one leaking and replace it
gopakumarg43
  • 76851 Answers
  • Posted on Oct 12, 2016
SOURCE: I have a Vizio e601i-a3 TV which powers on and shows vizio symbol fine then The screen starts flickering and power to the tv goes off after about 1-3 mins. Any suggestions on how. I can fix the Tv?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
gopakumarg43
  • 76851 Answers
  • Posted on Aug 03, 2018
SOURCE: My TV has no picture (black screen). I did the flashlight test and can see images. Replaced the power board and still the same issue. Yes I have audio but no video Vizio 60” e601i-a3. Please help.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts./
I have a Vizio E601i-A3 tv that has video problems.
You have a bad tcon board or the panel is bad but this set has some issues with the tcon board...you could try baking it if you wanted, its not going to hurt anything
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
The vizio set will not respond to remote to turn set on.
Point the remote at your cellphone camera and press a button. You should see a flicker from the remote if it is working. If no flicker then remote is defective. If you have a flicker then the problem lies in the t.v. could be the receiver or another issue in the t.v.
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
I have a Vizio e601i-a3 TV , an angry gamer threw the control and brother the screen. it till turns on ut it looks like shattered glass around the impact spot. I have been searching high and low on google...
The cost of the screen, and the tools needed to make it work with your current TV would be more expensive than it would be buying another TV. Go find the gamer that caused the damage and get them to buy you a new TV.
1helpful
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
