Question about Hunter Dryers
I need a mounting assembly for a type3 Hunter ceiling fan w/ light model#21944
    Top Expert:
  • Hunter Master
  • 55,370 Answers
Hunter would be a possible source.
Posted on Oct 08, 2019
6ya staff
SOURCE:
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
Anonymous
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
Posted on Dec 24, 2009
Anonymous
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Fity P
  • 6 Answers
SOURCE: Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
Posted on Mar 26, 2010
carl
  • 3640 Answers
SOURCE: The light on my hunter ceiling fan flashes on and
remove watt governor for lights. ( little black box). and wire lights direct. this is your problem.watt governors are used to reduce light output or energy. just remove it.
Posted on Jan 24, 2011
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
Where can I purchase a 3/4" downrod coupler for a
From your friendly neighborhood electrician - any electric supply (a business supplying parts to
the electrical & HVAC trade) will either carry Hunter parts, or at the very least be able to
order the parts - why: Hunter is manufactered in the USA. Nearly every other brand of ceiling
fan you'll find at your neighborhood Home Depot or Lowes is manufactured in China.
The typical ceiling fan will come with parts for two configurations: (1) flush, and (2) a optional
3-inch downrod, but commercial installations will somtimes use extended downrods.
The Hunter web site (http://www.hunterfan.com) catalog shows available downrods in several
lengths: 12", 18", 24", 36", 48", 60", and 72".
I found Hunter downrod specifics in the online "core products catalog," at:
http://s7d5.scene7.com/s7/brochure/flash_brochure.jsp?company=HunterFan&sku=Core_2011_Trade_Final&config=HunterFan/skin&locale=en&zoomheight=600&zoomwidth=800
May 30, 2011 | Hunter Dryers
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
How do I take my Hunter Model 20723 model fan down to put a different rod on?
there are a couple of bolts that hold the housing on, after removing the blades you should see more mounting bolts that attach to the ceiling....fyi disconnect power First!
Nov 06, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Sep 16, 2009 | Hunter Vaulted Ceiling Mount - Bright...
Modelo#23273 how do you mount the blades to the
Sounds like the blades were not made for this fan assembly--I'd take it back for exchange.
Aug 22, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Im installing a hunter remote control receiver in the ceiling mount. I have a red, black, white and ground wire from the ceiling. Which wire on the reciever do I connect the red wire to?
The red wire in the ceiling is probably used in a shared neutral circuit and not needed for the fan. If it's not capped off already, it should be.
Just use black, white and ground from the ceiling.
Charlie
Aug 16, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
67 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
